STD Tuning Engine Which turbo to om602?
k2igukast
01-24-2015, 03:07 AM #1
Hi!
I have om602 turbo engine in stock. Which turbo will be best for my pump? I wanna get maximum hp in stock pump, it will be maybe 220-240 hp? Maybe more or less?
Sorry for bad english, i am from Estonia.
k2igukast
Hi!
uli124125
01-24-2015, 03:32 AM #2
the better way is to enlarge the elements and let the turbo original Wink
do you have a manual or automatic tranny?
what year is your car?
do you have EDS?
turbo from 603 or 606 are good on 602, but 220-240hpyou wont get with stock pump. the egt will be so fucking high that you will have melting pistons.
first pump then turbo and intercooler
greets
uli
uli124125
do you have EDS?
greets
uli
k2igukast
01-24-2015, 05:48 AM #3
Manual gearbox. I swapped om602 to my 1992 w201. Somewhere i read om602 turbo stock pump max hp will be ~220hp. I wanna dieselmeken pump in future when pocket is full of money. Big Grin
k2igukast
MrHope
01-24-2015, 01:38 PM #4
im not an expert but i think maby 150hk with maxxed standard pump..
W124 300D 1985 (daily driver)
MrHope
swampmonkey
hx40 super
280
01-26-2015, 07:44 AM #5
i would not say you go above 150hp with stock pump, even that "low" the engine will start to behave "non stock" regarding return to idle and stability of idle, ive had the stock turbo, and a 180cc pump, and i reached perhaps 220hp with that pump.. you will gain "nothing" by swapping the turbo unless you get new elements in the pump.
daily driver
w115 240d 72hp 3.07 rearend
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
01-28-2015, 08:34 AM #6
HY25 will bolt on to the manifold, probably too small though.
