STD Other Projects w124 estate e300
w124 estate e300
w124 estate e300
jdmonlyb18
10-02-2014, 04:16 PM #1
hello i have been on here for awhile but never posted anything any way a few days ago i got a w124 e300 estate for breaking but i kind of got attached to it so my plans are 606a super turbo im not an expert so im sorry if i ask a pile of dumb questions
https://imageshack.com/i/p1GsbVxOj
https://imageshack.com/i/kqKR6j1cj
jdmonlyb18
jdmonlyb18
01-27-2015, 02:23 PM #2
haven't really done much here's some pics this is all fixed now thought i had some pics need to take some
[Image: IMG_0499.jpg]
[Image: IMG_0498.jpg]
[Image: IMG_0493.jpg]
[Image: IMG_0494.jpg]
[Image: IMG_0495.jpg]
[Image: IMG_0496.jpg]
[Image: IMG_0497.jpg]
fitting full gasket set and NA intake cam on the 606a
[Image: IMG_0542.jpg]
[Image: IMG_0543.jpg]
[Image: IMG_0557.jpg]
[Image: IMG_0559.jpg]
[Image: IMG_0562.jpg]
[Image: IMG_0563.jpg]
[Image: IMG_0564.jpg]
[Image: IMG_0565.jpg]
[Image: IMG_0566.jpg]
[Image: IMG_0567.jpg]
[Image: IMG_0577.jpg]
[Image: IMG_0578.jpg]
[Image: IMG_0579.jpg]
[Image: IMG_0580.jpg]
[Image: IMG_0582.jpg]
This post was last modified: 01-27-2015, 03:09 PM by jdmonlyb18.
jdmonlyb18
Mr_Robs
01-28-2015, 04:14 AM #3
Great pics of the teardown! How hard was fitting the NA intake cam? Did you change up the timing or just put it in the stock position? I bet that broken head bolt was frustrating Smile
Mr_Robs
Ksteen2
01-28-2015, 01:38 PM #4
did you get a complete gasket kit for it?
with head gasket and such?
I cant find a complete kit for it :o
car looks nice, hope u get some real power out of it Wink
This post was last modified: 01-28-2015, 01:38 PM by Ksteen2.
1#
Volvo 940 estate 1995
Originaly a d24tic
6speed cdi box
4,5" humongus cooler
Please wait, loading boost
Ksteen2
1#
Originaly a d24tic
6speed cdi box
jdmonlyb18
01-28-2015, 03:22 PM #5
thanks was OK to fit the cam im not really sure if there's much difference in the cams i don't know how to measure them right i just measured the lobe hight with a cheap pair of calipers the NA cam is like 1/2 mm maybe 1mm bigger cant remember lol yeah the broken cam bolt was annoying had the cam nicely timed and fitted then i couldn't find the torque setting found an old book with a 603 torque setting assumed it would be the same obviously not torqued 5 of them before that one broke lol was easy to fix just had to take the cams out again and it came out by hand
(01-28-2015, 04:14 AM)Mr_Robs Great pics of the teardown! How hard was fitting the NA intake cam? Did you change up the timing or just put it in the stock position? I bet that broken head bolt was frustrating Smile
yeah got it on ebay it was a head gasket set and a bottom set the head set was for 606 turbo from the w210 and bottom set was from a w124 e300 606 NA just email him and ask him what your looking for
it didn't have the valve cover gasket and the water pump gasket
http://www.ebay.co.uk/itm/190919274349?_...EBIDX%3AIT
(01-28-2015, 01:38 PM)Ksteen2 did you get a complete gasket kit for it?
This post was last modified: 01-28-2015, 03:44 PM by jdmonlyb18.
jdmonlyb18
