STD Tuning Engine om606 oil pressure
om606 oil pressure
om606 oil pressure
Sjevsspeed.nl
twincharged
59
03-15-2015, 04:31 AM #1
Anyone ever had problems with getting oil pressure on first start up?
The previous motor seized because apparently no oil pumping while stock mb pressure gauge was fooling me that it had oil pressure. now dropped in a new engine and aftermarked pressure sensor and gauge . runs good but reads pressure of absolite zero. tried making revs. Hope the pressurr sensor is broken. wil get an analog tester.
but annyone got any tips? Dont want to seize a second engine
Sjevsspeed.nl
03-15-2015, 06:23 AM #2
try to have a new pressure transmitter Wink otherwise u´ll have a pump problema!!! leak that kind.
Sjevsspeed.nl
twincharged
59
03-15-2015, 06:34 AM #3
Wel the first engine had a knokking valve lifter .
new engine sounds fine. the sender is aftermarket. gonna test it on a other car and wil test pressure with a analog gauge
This post was last modified: 03-15-2015, 06:36 AM by Sjevsspeed.nl.
Sjevsspeed.nl
Sjevsspeed.nl
twincharged
59
03-15-2015, 06:40 AM #4
The first engine came from a running car that i drove myself with no problems.
stil think its really strange that it didnt get oil. this engine camr from the scrap but sounds alot better after the swap..
the oil pump have a pretty simple bulletproof constuction.
done tons o swaps with engines from the scrap untested.
but.never ever had so much trouble with getting oilpressure.
i probably have pressurr now but got spooked. cant afford to seize another engine
This post was last modified: 03-15-2015, 06:45 AM by Sjevsspeed.nl.
Sjevsspeed.nl
03-15-2015, 02:15 PM #5
it should be the pressure transmitter. mb sells them cheap. but u can test the press by opening some oil line .
good luck.
good luck.
TurboTim
03-15-2015, 02:52 PM #6
Did you swap oil pans?
76 300TD custom lots of stuff
TurboTim
TurboTim
03-15-2015, 02:56 PM #7
I swapped to older pan from my 603 and it appeared that it would fit but it was bottomed out on pickup and gave me no oil pressure. You can swap the pickups from the winglet in the oil pan but it's tough.
TurboTim
Sjevsspeed.nl
twincharged
59
03-15-2015, 03:15 PM #8
Yes i harve swapped a om603 sump. buy apparently that schouldnt be a problem. the only difference i saw was a notch in the front to clear the stabilizer. i do have a om606.910 pan . if better il swap them out but hope i can manage in the car.
had to pull the block 3 times last week
This post was last modified: 03-15-2015, 03:16 PM by Sjevsspeed.nl.
Sjevsspeed.nl
TurboTim
03-15-2015, 03:51 PM #9
You can run that pan but you gotta swap the pickup.
TurboTim
TurboTim
03-15-2015, 03:54 PM #10
You can remove the pickup from the 606 motor and install it in the removable winglet. It's not a super fun job but u didn't have any problems getting it done. The pickups are about 1/2 inch difference. If you have any questions you can ask me.
TurboTim
Sjevsspeed.nl
twincharged
59
03-15-2015, 04:03 PM #11
Wel i dont have the pickup from the 603 anymore. just have a complete om606.910 from w124 .so a sump and a pickup. So i can either swap that pan. or pan and pickup or i have to get a om603 pickup. but anyhow the pan has to come of. so its basicly the same amount of work.
but thnx for ur info. But i just swap thr schould it be giod then? Or does the na also have a differend pickup?.
Also the.oilpressure sender i was using was aftermarket and brand new. the mb sender was broken before and fooled us. it gave 3 bar pressure even with no engine in
Sjevsspeed.nl
TurboTim
03-15-2015, 06:53 PM #12
Pan doesn't have to come off if you get a 603 pickup.
TurboTim
Sjevsspeed.nl
twincharged
59
03-16-2015, 06:02 AM #13
That would be the easiest option. but we sold the om603. I do have the om606na laying around
Sjevsspeed.nl
TurboTim
03-16-2015, 09:44 PM #14
What car is it in? My 606 oil pan wouldn't work in my W126 chassis.
TurboTim
Sjevsspeed.nl
twincharged
59
03-17-2015, 02:11 AM #15
Its in a w124 estate. with 722.6. Wich fills the trans tunnel completely so i have to see how much i can lift the engine
Sjevsspeed.nl
Sjevsspeed.nl
twincharged
59
03-17-2015, 01:23 PM #16
Got a 603 oil pickup. om606 na sump had some differences that i difnt want to nof. had oil lines running to thermostat housing. so i managed to finf 603 pickup tube and gonna swap it this week
Sjevsspeed.nl
TurboTim
03-17-2015, 03:19 PM #17
Yeah get a 603 pickup. It's going to be easier in all ways. You will have to move the motor forward or cut your crossmember Because the pan does go back about an 1inch more. I also have a 722.6 and it just wasn't going to happen at least anyways nicely.
TurboTim
Sjevsspeed.nl
twincharged
59
03-30-2015, 12:18 AM #18
Thanks TurboTim. ir solved a problem. managed to swap it just by lifting the engine and trans
Sjevsspeed.nl
