STD Tuning Drivetrain OM60x flywheel for short shaft gearbox?
hents99
03-22-2015, 09:20 AM #1
Are you interested in flywheel for OM60x and M102/103/104/111 engines equipped with dual-mass flywheel?
For gearboxes with short shafts 717.450 etx.
Approx 3.55kgs without starter ring. OEM starter ring can be used on it.
For 184mm / 7.25" clutch.
[Image: 34638-hooratas_2mass2.JPG]
[Image: 82474-hooratas_2mass.JPG]
At the moment I have flywheels that replace single mass flywheels.
These will fit with taller shaft gearboxes like 717.404 etc.
[Image: dsc_2974.jpg]
This post was last modified: 03-22-2015, 11:01 AM by hents99.
hents99
CRD4x4
CompoundSuperTurboDiesel4x4!
399
03-22-2015, 10:25 AM #2
Wow! That's less than 8 lbs!
I've been looking for a single 60x flywheel closer to 30 lbs.
How would such a light flywheel work with a boosted 60x?
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
hents99
03-22-2015, 11:17 AM #3
Extra weight is not a problem  Wink
Starter ring weight is approx 1.1kg
hents99
DanielK
Big Plans, No Clue
98
03-24-2015, 04:22 AM #4
What do the single mass flywheels run for? I have a 2.3-16 laying around that needs love one day.
[Image: FalkonSig.png]
DanielK
hents99
03-24-2015, 04:29 AM #5
Single mass flywheel price is 350 Euros and these are in stock.
I`m using same flywheel with 3-disc Alcon clutch on my 2.3-16 turbo.
hents99
DanielK
Big Plans, No Clue
98
03-24-2015, 10:18 AM #6
1987 still had the single mass, right?
DanielK
03-24-2015, 10:30 AM #7
Yes yes
Yes yes
