722.6 Information wanted
First post on this forum, looking for some information on the 722.6 for a conversion in my Land Rover 90.
Having done a bit of searching and reading on this forum I think I am looking for a 722.634 gearbox. I want the higher ratio W5A580 version for the gearing but the strength is an added bonus.
Can someone confirm what model Mercedes in the UK would have been fitted with a W5A580 that will bolt straight onto an OM606?
Thanks in advance.
(03-28-2015, 04:10 AM)erx They are the same, w211 have some internal improvments but they both will bolt on. Also w203 c270cdi.
(03-29-2015, 07:27 AM)erx Code starting with R140... is for housing only but it seems to be the right one.
You can see it on the last picture, little square on the side of the housing. Sometimes numbers are hard to see.
http://www.ebay.com/itm/MERCEDES-CLK-W20...2a4cdf96c6
(03-29-2015, 07:50 AM)erx You can see it on the last picture, little square on the side of the housing. Sometimes numbers are hard to see.
(03-31-2015, 11:18 AM)erx 722.640 seems to be newer version from w211 or w203, 722.634 is from w210. I belive they only have internal differences and maybe different flexidisk flange.
