STD Tuning Drivetrain 722.6 Information wanted
ross
03-27-2015, 04:51 PM #1
First post on this forum, looking for some information on the 722.6 for a conversion in my Land Rover 90.
Having done a bit of searching and reading on this forum I think I am looking for a 722.634 gearbox. I want the higher ratio W5A580 version for the gearing but the strength is an added bonus.
Can someone confirm what model Mercedes in the UK would have been fitted with a W5A580 that will bolt straight onto an OM606?
Thanks in advance.
ross
Thanks in advance.
erx
w202 om606
323
03-27-2015, 05:48 PM #2
Only W5A580 for OM606 is from 270CDI.
erx
ross
03-27-2015, 06:50 PM #3
(03-27-2015, 05:48 PM)erx Only W5A580 for OM606 is from 270CDI.
From which model though? W210? or W211? I could not find the information.
ross
erx
w202 om606
323
03-28-2015, 04:10 AM #4
They are the same, w211 have some internal improvments but they both will bolt on. Also w203 c270cdi.
erx
ross
03-29-2015, 05:51 AM #5
(03-28-2015, 04:10 AM)erx They are the same, w211 have some internal improvments but they both will bolt on. Also w203 c270cdi.
The ebay seller has given me this number from the box: r140271 26 01.
Is that correct for a 2001 c270cdi?
Edit: http://pages.ebay.com/link/?nav=item.vie...1612382926
This post was last modified: 03-29-2015, 05:53 AM by ross.
ross
erx
w202 om606
323
03-29-2015, 07:27 AM #6
Code starting with R140... is for housing only but it seems to be the right one.
erx
ross
03-29-2015, 07:39 AM #7
(03-29-2015, 07:27 AM)erx Code starting with R140... is for housing only but it seems to be the right one.
Where on the box will it show the 722.6XX number so I can make sure? Its an hour each way from me.
and by the way, thank you for the help... It is much appreciated as I'm new to MB stuff!
ross
erx
w202 om606
323
03-29-2015, 07:50 AM #8
You can see it on the last picture, little square on the side of the housing. Sometimes numbers are hard to see.
http://www.ebay.com/itm/MERCEDES-CLK-W20...2a4cdf96c6
This post was last modified: 03-29-2015, 07:51 AM by erx.
erx
ross
03-31-2015, 03:33 AM #9
(03-29-2015, 07:50 AM)erx You can see it on the last picture, little square on the side of the housing. Sometimes numbers are hard to see.
Right the number he has sent me doesn't tie up to the list I have.... its 722640. The number isn't on the list!
Any idea what it is then?
ross
erx
w202 om606
323
03-31-2015, 11:18 AM #10
722.640 seems to be newer version from w211 or w203, 722.634 is from w210. I belive they only have internal differences and maybe different flexidisk flange.
erx
ross
04-01-2015, 11:41 AM #11
(03-31-2015, 11:18 AM)erx 722.640 seems to be newer version from w211 or w203, 722.634 is from w210. I belive they only have internal differences and maybe different flexidisk flange.
Found the information in your thread!
http://www.superturbodiesel.com/std/show...4#pid69944
The 722.640 is from either: W211 220CDI/270CDI/280CDI/
So from that it looks like it should bolt straight onto the OM606 Big Grin. Assuming the 647.961 has the same bellhousing pattern.
ross
