STD Other Open Help me with my project
04-17-2015, 08:19 AM #1
Hi, I want to build a 1200hp OM606 with triple compound turbos but I'm on a tight budget. Tell me what turbos to get out of the junk yard. Can I adjust the ALDO on an OM603 pump to get this much HP? It it hart swapping turbos because my apartment complex has rules about working on cars in the parking lot. I don't want to weld anything either so I was wondering who to buy the parts from cheap. I also need to make this reliable and easy to drive because it's my Mom's car. Can I use a transmission from a Yugo? Also, my go-cart has a centrifugal clutch, can I make that work on this engine?
led-panzer
04-17-2015, 08:48 AM #2
1985 300D 280,000 miles RIP
led-panzer
led-panzer
04-17-2015, 08:52 AM #3
Of course due to the inability to side scroll I cant delete the first one
This post was last modified: 04-17-2015, 08:56 AM by led-panzer.
led-panzer
Duncansport
04-17-2015, 09:40 AM #4
Haha. Love it!!
Duncansport
Haha. Love it!!
mytmousemalibu
04-18-2015, 01:46 AM #5
Well you don't need triple turbos, just a mega big single turbo! You can build it yourself for cheaps! You need to buy some jet engine blades off ebay and some of those....uh...Go Cart axle bearings and axle for the turbo shaft. The housings are at Home Depot, those shiny metal trash cans, those are perfect! Some PVC boost pipes too! You don't need a welder if you have your JB Welder's license, thats good enough! You don't need a big injection pump either, just buy a junkyard windshield washer pump and hook it up to a pop bottle of diesel fuel under the hood and put the hose to the intake of your new turbojetcharger! If you can't afford the turbojetcharger, I bet yo can get a diesel locomotive turbo for cheap, that should work good too! When you want power just hit the washer button! I think you'll make way more horsepowers than 1200!
_______________________________________________________________
87' 300D daily driver, under the knife for a OM606 superturbo build!
82' 300SD~ Parting Out
93' 300TE~ Parting Out
89' 300E  ~ Parting Out
83' 240D~ Project "Cheap Drive"
03' 2500HD Dmax, lots of goodies
88' RX7 10th AE, 13B rotary Track Car Project
73' Datsun 510 wagon~ future project
79' Camaro Z28~ future project
mytmousemalibu
04-21-2015, 02:58 PM #6
Don't forget, you're gonna need more fuel for that big turbo! I suggest getting one of the big propane cylinders (like the one your grill uses) and put it in the passenger floor board, and running a hose up to the front of the intake. If you have a paper filter you should just be able to stab the hose through. Then once you start moving you can reach over and open up the valve on the cylinder!
waz
04-22-2015, 09:37 AM #7
Has anyone considered acetylene instead of propane injection?
This post was last modified: 04-22-2015, 09:37 AM by waz.
waz
04-22-2015, 01:54 PM #8
Ray, I hear ya!  Don't let the naywayers get you down, you Moms car will be fine
(04-22-2015, 09:37 AM)waz Has anyone considered acetylene instead of propane injection?
Actually, it has.  The problem is that acetylene is explosive, and highly volatile.  You would blow a rod out as soon as you turned it on.
mo1971fordcrew
Glug Glug Glug
29
04-22-2015, 07:08 PM #9
I think it's totally do-able. You might be pumping so much boost through it that your intake valves may need a stronger spring. What about suspension coil springs from a w123 or something? Just cut some holes in the valve cover for the longer springs and JB weld some coffee cans over the springs so oil doesn't splash everywhere.
1980 Mercedes 300TD - Engine: 1983 OM617, W126 rear "blue" springs, turbo front springs, ALDA and rack limiter removed, boost @ 12psi. 2.5 inch exhaust off 6.9 diesel, straight pipe. Manual climate control. 2.88 diff.
mo1971fordcrew
