STD Tuning Engine om617.952 timing chain tensioner rail replacement
atypicalguy
06-01-2015, 09:09 AM #1
I just put a new head on and am wondering if I can still replace the big curved tensioner rail. Not the little one with the slide hammer pin, but the big one that the spring tensioner pushes on. It is in OK shape but I have a new one and my WIS doesn't go back to 1985 so I don't know if I need to pull the main crank pulley to get at the bolt, and if I do that, I don't know if it will fit through the opening in the head.
Anybody replace that one? Where can I get the workshop instructions?
Thanks,
Karl
This post was last modified: 06-01-2015, 03:59 PM by atypicalguy.
atypicalguy
Thanks,
Karl
atypicalguy
06-03-2015, 09:15 AM #2
(06-01-2015, 09:09 AM)atypicalguy I just put a new head on and am wondering if I can still replace the big curved tensioner rail. Not the little one with the slide hammer pin, but the big one that the spring tensioner pushes on. It is in OK shape but I have a new one and my WIS doesn't go back to 1985 so I don't know if I need to pull the main crank pulley to get at the bolt, and if I do that, I don't know if it will fit through the opening in the head.
Thanks,
Karl
Due to overwhelming response, I have obtained the following manual, which I hope will prove useful to others maintaining om617.95 series motors:
https://www.dropbox.com/s/iku0w8b6d500ww...a.pdf?dl=0
atypicalguy
Thanks,
Karl
atypicalguy
06-03-2015, 11:51 AM #3
You're welcome.
atypicalguy
You're welcome.
NZScott
HX30W 73/44mm
398
06-04-2015, 12:19 AM #4
Saved. Never know when it'll come in handy, cheers
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
atypicalguy
06-04-2015, 03:13 AM #5
Between this and epcstartekinfo one cam do a lot of damage on a later 617. I am sure there are similar manuals for the car itself; rear subframe etc would be nice to have for example.
atypicalguy
06-08-2015, 03:41 AM #6
They always got deleted by dickhead so it's nice to see manuals show back up
atypicalguy
06-08-2015, 03:54 AM #7
I thought it was weird they are not in a sticky somewhere, but whatever. Happy if it comes in handy.
Hey maybe you guys can help. On the drivers side of the head in front there are two ports for screw in sensors. I have no idea what they are, as there is another port for the temp gauge sensor at the back of the head, and two sensors on the thermostat also.
I'm looking through a bucket of parts at what might possibly go there, and I have one VDO part and one Bosch part, but both look like temp sensors. I sent it out for rebuild with the sensors in place, so I didn't actually remove them.
The head diagram in the manual shows the two ports, a hose fitting at the back of the head for the heater hose, and a port at the back for the temp gauge sender unit. I haven't found where it shows what screws into these two fittings.
Karl
atypicalguy
Karl
