STD Other Projects 99 w210
99 w210
99 w210
sendo
06-26-2015, 10:54 PM #1
is putting a turbo just bolt on ? for a Holset HX35 turbo do I need change the exhaust manifold? this car is stock, should i do the super chip to it?
i think i would like 350 hp what else will have to be changed?
thanks, sendo
sendo
thanks, sendo
CRD4x4
CompoundSuperTurboDiesel4x4!
399
06-27-2015, 07:02 AM #2
The stock turbo and exhaust manifold mate to one another with a unique triangular flange with 3 bolts/studs. The hx35 (and most other turbos) use a rectangular 4 bolt flange so it is not bolt-on.
I don't have experience with the chip tunes but I know the stock exhaust manifold will perform poorly (high back pressure and EGT).
My opinion is to try to improve the efficiency of the intake charge air with bigger/better intercooler, chip tune, EDC maxed out, water/meth injection, etc. before swapping out turbos & custom manifolds.
The modest increase you'll get might satisfy your desire for more power but it'll definitely be cheaper than custom manifolds.
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
sendo
06-27-2015, 01:17 PM #3
(06-27-2015, 07:02 AM)CRD4x4 The stock turbo and exhaust manifold mate to one another with a unique triangular flange with 3 bolts/studs. The hx35 (and most other turbos) use a rectangular 4 bolt flange so it is not bolt-on.
what is EDC?, and the manifolds have to be custom made no one sell's them made already for this engine?
thanks, sendo
sendo
thanks, sendo
CRD4x4
399
06-27-2015, 02:24 PM #4
Oh boy. EDC refers to the electronic diesel control type of fuel injection pump (that you have) which can be swapped for an earlier mechanical version from either a OM606 or OM603 or remain electronic if only chip tuning.
All this stuff is covered many places on this and other sites. You've got some reading to do ;-)
CRD4x4
sendo
06-27-2015, 07:30 PM #5
(06-27-2015, 02:24 PM)CRD4x4 Oh boy. EDC refers to the electronic diesel control type of fuel injection pump (that you have) which can be swapped for an earlier mechanical version from either a OM606 or OM603 or remain electronic if only chip tuning.
yes i need to read more on this, but alot of the stuff i find seems to extreme like the guy with the turbo and blower, or sending the pump away for bigger elements, will that be something i have to do to get 350hp?
sendo
06-28-2015, 07:35 AM #6
Here's an adapter for your exhaust manifold. I suggest getting an entire tubular manifold though. They're available from many sources.
http://www.dieselpumpuk.com/shop/manifol...-adaptors/
CRD4x4
399
06-28-2015, 08:02 AM #7
(06-28-2015, 07:35 AM)raysorenson Here's an adapter for your exhaust manifold. I suggest getting an entire tubular manifold though. They're available from many sources.
That turbo adapter for the cast OE manifold is pretty tits. I might have to get me one of those.  Big Grin
This post was last modified: 06-28-2015, 08:04 AM by CRD4x4.
CRD4x4
