STD Other FS / WTB / Buying guides W123 / OM617 upgrade parts...
SurfRodder
Jackass Extraordinaire
611
08-25-2015, 01:29 AM #1
Hello all.  I am looking to get rid of a few things from my W123 / OM617 spare parts pile...all prices do include shipping to the contiguous 48 or delivery within 50 miles of 91977.  I wlll post pics tomorrow morning when I get to my big computer.
1985 CA intake filter housing (only). Unfortunately the housing was the only part there on the donor (my guess is someone forgot to grab the rest of the parts on a previous purchase). I think I posted some pics of what they look like somewhere around here or PP.  You will have to make a bottom mount bracket and attach a hose to some other custom job to draw air from inside the fender.  $100 obo.
Custom welded and powder coated (Olive Green speckled over Black base) oil cooler hard lines to attach AN flex hoses (between oil filter housing and stock oil cooler.  You will need to provide your own reusable AN fillings (I think 45* ended up working best on all ends...and flex hose obviously...I recommend the black nylon braid type for ease of routing and fitting install) for each side and the metric threaded adapter fitting for the oil filter side since I reused those on my car.  Part numbers should be in my w123 build thread.   $50 obo.
Matching powdercoatd IP hardlines for above oil cooler lines (unused since powder coated).  $50 obo or $40 with oil lines. I also have a valve cover to match these but need another one to replace on my 617 to protect its internals. I know I have a spare somewhere so if someone is interested in all pieces I will find it and throw this one In for free.
Stock oil cooler from my '83 300D.  Did not leak before removed.  I upgraded to an Earls oil cooler when I ran the new braided flex lines and AFCO alum rad.  $15 or free with purchase of oil lines.
This post was last modified: 08-25-2015, 10:20 AM by SurfRodder.
OBK# 62
SurfRodder
OBK# 62
SurfRodder
611
08-27-2015, 09:21 PM #2
No offers on any of this stuff? I have no idea what fair prices are on these things nowadays. If you see something you need/want send me a PM.
OBK# 62
SurfRodder
OBK# 62
08-27-2015, 11:43 PM #3
I wish you had the "accessories" to the California air cleaner. I need those, e.g., the tube or snout to the fender, et cet. I've been looking for a year. They are a dealer item at $12.00 but it's NLA. I think there are a few other tidbits for that style of air cleaner. I got the box, but missing a few items. Any chance you have those packed away???
SurfRodder
611
08-28-2015, 02:20 PM #4
No.  I distinctly remember them not being on the donor.  I do have some pictures somewhere (apparently not anywhere here...must have not posted them before).  I'll check my archive drive to see if they are there.  An appropriate ABS elbow in conjunction with the other style intake hose would work well with minor modification.  The bottle is a simple stamped steel bit that has three legs. At least one attaches to the lower ledge/lip of the inner fender well / frame rail. I think I may have had to drill one hole to attach the lower mount to the body and obviously cut away a big hole for the intake elbow.  The lower mount also has a simple rubber bushing that accepts the bottom of the air cleaner housing and prevents rattling.
They do come up from time to time here though.  I'll keep an eye out for you.
This post was last modified: 08-28-2015, 02:21 PM by SurfRodder.
OBK# 62
SurfRodder
OBK# 62
mike-81-240d
more like mike-84-300d now
427
08-28-2015, 05:29 PM #5
Are the hardlines in good condition? Mine have hairline cracks and cylinder number 3 is weeping at the injector. If they're good I'll PayPal you today.
mike-81-240d
SurfRodder
611
08-28-2015, 08:00 PM #6
They were good condition j/y lines with good chromate coat before they were powder coated.  I'm sure they will work well but if not I'll refund you.
This post was last modified: 08-28-2015, 08:00 PM by SurfRodder.
OBK# 62
SurfRodder
OBK# 62
mike-81-240d
427
08-29-2015, 03:13 AM #7
PayPal?
mike-81-240d
PayPal?
SurfRodder
611
08-29-2015, 11:43 AM #8
Email sent thru forum system.
OBK# 62
SurfRodder
OBK# 62
mike-81-240d
427
08-29-2015, 02:53 PM #9
Payment sent for IP lines.
mike-81-240d
