A few words to china turbos [review after 20 000km]
Heho Guys.
I just want to give a short feedback about my china holset 35 turbo, cost 280 Dollar.
http://www.ebay.de/itm/HX35-HX35W-T3-Tur...48828a2547
I drove it 5000km on 1.5 Bar without intercooler, then 15 000km on 1.5 Bar with intercooler.
No Problems until now.
It came with around 3/10mm wave radial play. This is unnoticable when connected on the oil line. Then you have no play.
This doesnt change until now. I get nice power output on 120cc of fuel and 1.5 Bar.
https://www.youtube.com/watch?v=fAuPN8taUbo
I have the feeling that the internal wastgate does not seal so good. On one day i have goodlike spooling. On other day its very bad. I think that the closing cap deforms because of the massive heat.
Pros:
- Nice Price (Around 1/3 of original)
- Good Power output
- Good lifetime
- 800°C thats 1073k are no problem.
Cons:
- A bit later spooling than original
- Internal wastgate not perfect.
- I dont want to try 2 Bar with intercooler (i dont want to destroy turbo)
Just you can think about if the high price is worth it.
I've heard rumors that the problem is balance-so if you have it re balanced when you buy it, then you're in the clear. Do you think that was the issue?
Sorry, I meant that the radial play would be caused by poor balancing at the factory
Same here, works good so far some 15 000+. HX35W and HX30.
I think that the chinachargers back in the day weren't the best owing to quality control issues, I think that the current ones are actually pretty well built and are using the same design as some of the older Garrett etc designed turbos (now that they have moved on). I think if the quality was too bad then there would be loads of refunds and the business wouldn't exactly remain in business.
I bought a dodge cummins that had one on it. Eventually took it off for bigger turbo. The turbo was still very tight (no shaft play) and spun great, only problem was the inducer size was smaller than stock turbo inducer so ran less boost and higher egt. I would definitely run one on my car but just make sure the inducer is the same size as a stock Holset.
the china crap , is a question of "quality control" and fabrication / manufacture tolerances. like AK47 , it shots kils but 1 in 10 100mts shot hit the targuet.
I understand that not all members have the Money for Garret crap, but one of the best things i done was buying garret original crap for 400€ and 150€ of reconditioning, is lasting for ages and running very well.
china is 250 and if u´re lucky last 50.000 km . and u buy a Mitsubishi and last 20.000, as the ones in the BMW 170HP engines .
and sometimes it takes the engine with it!!!
regards
(09-05-2015, 04:17 AM)barrote the china crap , is a question of "quality control" and fabrication / manufacture tolerances. like AK47 , it shots kils but 1 in 10 100mts shot hit the targuet.
regards
regards
yep, u have a point mitch ,
the thing i have never seen a compressor failing in such a way that the ingestion of debris by engine constitutes a problem(at least in piston engines) . same happens for the turbine side, maybe some metal pieces get stuck in the catalist filter something that shouldn´t be a major issue.
what about seal failure!!! wich is about 90% of the failures, sometimes u may loose the all engine just cause it starved some oil
and what about drinking oil from new? i dont know about there , but in my planet a liter of not so bad oil is 20€ more less .
i had a engine doing 1 liter 1000km, thats bad.
but is up to u, or to all , as i said not everybody has budget to garret crap....
(09-06-2015, 08:33 AM)barrote but in my planet a liter of not so bad oil is 20€ more less .
yep , u dont even know what is going on here with the F$#%$ engine oil, Mobil 1 is about 3 and something in store, 60 liter drum abou 10€ castrol edge is even more expensive, and by tthe way i dont have a shop, i´m a private. sometimes i can buy from friends but is like 300€ a can of 25lts wich makes a litle over 10€
regards
We had a blade on a compressor wheel break off one of our tractors one time and it got trapped underneath the other blades and stalled the compressor wheel and shaft.
Wasn't a china turbo, but barrote was said about ingestion stuff so I thought I'd share
yep i see , but u do run great boost right?, like i do! at the moment peak 3.5 / 4BAR absolute. the 4 bar is a peak thing related with default in the installation.
my major problems have been with sand ingestion, and that is a F$#% thing to have.....
regards
(09-14-2015, 01:41 PM)barrote yep i see , but u do run great boost right?, like i do! at the moment peak 3.5 / 4BAR absolute. the 4 bar is a peak thing related with default in the installation.
regards
regards
lly
Not really, just a stock farm tractor. Maybe 2-2.5bar max? But the turbo had many, many hours on it.
How do you get sand in a turbo, no air filter?
[/quote]
nop my car is day driver, so usually there lot of sand asside the roads , driving behind the others cause that to happen, i was using a washable filter , and the suction is so great that it ingests small sand grains , and u know what happens after. maybe i have to change to a diff kind of filter!!!! at the moment i´m using filter shirts made of women nets.... seem to be working good.
rgards
I hate gauze type filter elements for that reason. Foam and paper FTW.
