Controlling a vnt with wastegate?
I am finally a happy MB owner. 1988 190e 2,5td
Thinking of a regular pneumatic actuator connected to the vanes. And an additional wasegate. Using a fairly small turbo.
-Have a microswitch connected to throttle pedal. Below a certain engine load (cruisemode) the wastegate will regulate intakemanifold boost to 5 psi. Vanes fully closed position.
-When throttle is advanced beyond cruisemode an electric valve will close the boostline to the wastegate. Wastegate closes.
-manifold- and exhaustboost builds up. VNT actuator opens and will travel to its mechanical stop. Let`s say 15psi.
-Exhaust pressure and temp will further increase as exhaustflow exeeds the small turbo designlimits.
-Now is my golden thought. Have the WG open at a certain EGP. Have a pressureline directly from exhaustmanifold to wastegate diaphragm. 25 psi EGP maybe? Maybe a "exhastgas intercooler" is needed in exhastpressureline to avoid frying the WG diaphragm..?
-This setup will require a pressureline "T" cross, two one-way valves and a pressure regulator(orifice) making 25egp psi become 5psi on the wategateclock.
With this setup the manifoldboost will only be controlled at bottom and far end of the pressurescale. Unlike FI`s 0-5-10-15psi thoughts.
Any thoughts or comments? SHOOT!
I have also been hired to work on a bosch electro-diesel workshop the rest of this year. Good times
It sounds pretty much the same as what I'm doing but with pressure instead vacuum.
Opening wastegates or vanes based on exhaust manifold pressure won't work.
In situations where the exhaust manifold pressure is highest, you need boost the most. For example accelerating with a cold exhaust manifold and turbo (from a standing start) and high rpm full load is where you need boost. An exhaust manifold actuated wastegate will drop boost in these situations and lead to excessive EGT's.
Oki, see. Learn things every day.
Would it then maybe be wiser to have the wastegate open at ~2psi intakemanifold pressure more than the vnt actuator -and in that way controlling the bypass for the turbo to avoid high emp and egt? I am thinking of start to look for a stock 110hp vw tdi vnt. They can afaik easily push 130+hp. Perfect for a stock fuelpump 602?? Is this idea already doomed?
(11-14-2009, 08:54 AM)lars I am thinking of start to look for a stock 110hp vw tdi vnt. They can afaik easily push 130+hp. Perfect for a stock fuelpump 602?? Is this idea already doomed?
(11-14-2009, 08:54 AM)lars Oki, see. Learn things every day.
I'm not aware of any manufacturer that controls pre-turbo backpressure for anything besides EGR function/flow.
Thanks. EGP as controlinput is scrapped. But too high egp screws up fuel efficiency, right?
Googled gt2052v and it looks like it is mounted on quite a few german 2-2,5 diesels from late 1990s and on and should be easily available. All seems to be controlled with a actuator. goodgood.
(11-14-2009, 04:24 PM)lars But too high egp screws up fuel efficiency, right?You should only see high exhaust pressures during hard acceleration.
