Rare parts for sale, turbos, heads, flywheels etc...
I've decided to clear out some of the parts I've gathered over the years. The list is below and I may be adding to it as I dig stuff out of the shop.. I will post a few pics but if you want detailed ones for each part please email me. Also I don't check pms very often so best way to contact is by email: peter_kawalec@hotmail.com
All prices (quoted in USD)may negotiable especially if you get multiple items
* 0.55 trim om603.97X garett turbo (came from 3.5L rod bender), good shape $200
* 0.5 trim om603.96X gartett turbo (stock on a 3.0L motor), good shape $150
* om603.96X KKK turbo, appears to be in good shape but has a fair bit of outside rust $100
* om603.97X water pump with housing (I was told it's larger than stock 3.0L pump) $60
* om603 cylinder head #17 casting, pressure tested. Bare head (cam, valves, prechambers also available for extra $$$) $300
* om61X adapter plate for a Jeep AX5 transmission. Includes 8.5" clutch disc to fit 240D flywheel. $150
* 5pc angled prechambers to fit late model om60X. Cleaned and in Perfect shape. $100
* om616 manual flywheel (to fit 8.5" clutch) $250
* m102 manual flywheel (to fit 8.5" clutch) $150 or $200 with stock clutch disc and pressure plate. (I have bored out identical flywheel to fit 300E 9.5" clutch, works perfect in my w126 300SD manual conversion car)
* m103 2.6 manual flywheel (came form euro 190e 2.6 w ith 9" clutch). This is a rare one because it has 3 timing tabs needed for 6cyl gas engine conversion. $300.
* manual pedal box to fit w201 w124, without clutch master cylinder. $100
* 722.3 automatic transmission from 87 300SDL. Mercedes Benz Rebuild with less than 30k miles on it. $300 (priced low because shipping will likely be pricey)
I also have a ton of spare parts for om603.96 and 603.97 (sorry, no cranks left). Please contact if you need something.
If you want to get an idea of shipping costs feel free to check it out on fedex/UPS site. Parts ship from Halifax NS, Canada
I'm interested in the trans adapter for the Jeep AX-5 trans.
