STD Tuning Engine simple oil pressure tap on my w210
50harleyrider
GTA2359VK
397
02-24-2016, 07:38 AM #1
Where would be the easiest location to connect a mechanical oil pressure gage to my OM606.962? Also what would be the ideal warm pressures at idle and 2500 RPM? I'm running 5w40 Rotella T6 in it now.
This post was last modified: 02-24-2016, 07:40 AM by 50harleyrider.
50harleyrider
zeeman
02-25-2016, 02:10 PM #2
(02-24-2016, 07:38 AM)50harleyrider Where would be the easiest location to connect a mechanical oil pressure gage to my OM606.962? Also what would be the ideal warm pressures at idle and 2500 RPM? I'm running 5w40 Rotella T6 in it now.
I tapped one of the plugs in the oil filter housing to 1/4 pipe  worked fine. Oil pressure on a OM 606 I just put into a 2007 Jeep JK, warm at idle 20 psi 40 at 2500.
zeeman
50harleyrider
GTA2359VK
397
02-25-2016, 02:39 PM #3
Thanks Zeeman. I need a lesson in posting photos directly on the forum. Do I see a spot of ketchup on your IP? You did eat off it, right? Awesome!
50harleyrider
zeeman
02-25-2016, 04:56 PM #4
(02-25-2016, 02:39 PM)50harleyrider Thanks Zeeman. I need a lesson in posting photos directly on the forum. Do I see a spot of ketchup on your IP? You did eat off it, right? Awesome!
I am no computer expert either, you don't know the half of it on this conversion I did. I worked 4 months straight on this conversion for a customer, and he didn't appreciate any of it.
zeeman
