STD Tuning Engine OM60x rod dimensions
baldur
Fast
511
02-23-2016, 06:40 AM #1
I'm rebuilding an OM662 and they have been known to stretch the rods beyond their usable limit before breaking. These appear to have 145mm long rods compared to the 149mm long rods on the OM602, as well as a 26mm wrist pin.
I'm wondering if there are any other beefier rods available and where to source them from, possibly from the direct injection OM602 2.9?
Baldur Gislason
baldur
Baldur Gislason
02-23-2016, 02:32 PM #2
Don´t know the size... did not bother to measure.... if it helps
u can consider the OM611/2/3 OM646/7/8 Rod,  the wrist pin in this is 30mm  if u want let me now i´ll post a pic too.
All is about the piston u want to use....
Regards
This post was last modified: 02-23-2016, 02:42 PM by barrote.
Regards
baldur
Fast
511
02-23-2016, 05:57 PM #3
Yes the rod pictured is the right length and looks like it has a 28mm pin. The 662 piston has a 26mm pin.
I want to use any piston that works with the 2 valve IDI head and the 89mm bore of the 2.9, although it would be nice to swap to a 4 valve piston and OM605 head.
Baldur Gislason
baldur
Baldur Gislason
02-24-2016, 09:29 AM #4
OM 601 2.3 TD found in sprinters and vitos have that 89 with the 28mm and is 2 valve as the 662.
89mm 4 valve piston is the 604 2.2 , the wrist pin is 26 so compatible with your rods and 4 valve head Wink
regards
regards
tgg416
02-24-2016, 03:42 PM #5
Here you have diffrent to pick from :
Price for one is 1200Skr a piece, thats about 135$
http://www.acm-ab.se/vevstake-spm-h-profil/298
Gwagen 460, om606.962. 722.6 Ole Fejer controller++
Gwagen 463, shitty 603,,,,at the moment,,,
Gwagen 463, 270cdi
tgg416
Gwagen 463, 270cdi
