Will this torque converter fit the 606 bellhousing?
to answer your question yes a 270cdi torque converter will fit
i was able to get a remanufactured Dacco MC18S
sent from a usa company cheaply throught the global shipping program.
might be worth looking into, worked out cheaper than a 2nd hand one locally or from uk
this link shows all internationally shipped items
http://geo-ship.com/?c_keywords=mercedes...erType=All
I have 320CDI converter with om606 and it is the same size as converter from 300td. Only difference is bolt pattern to flexplate, I have custom made flexplate to make it fit. Maybe 270cdi has the same bolt pattern as 300td, then it will fit without changing flexplate.
270cdi converter has same bolt pattern as 606 flexplate, just got mine done at local shop (one more plate to the lock and normal service) and did trial fit it before that it fits perfectly.
320cdi converter I have too, that has different bolt pattern, like erx said. But I didn't test does it fit to the 606 bellhousing..
(02-24-2016, 06:04 PM)erx I have 320CDI converter with om606 and it is the same size as converter from 300td. Only difference is bolt pattern to flexplate, I have custom made flexplate to make it fit. Maybe 270cdi has the same bolt pattern as 300td, then it will fit without changing flexplate.
(02-26-2016, 01:39 PM)Tito(02-24-2016, 06:04 PM)erx I have 320CDI converter with om606 and it is the same size as converter from 300td. Only difference is bolt pattern to flexplate, I have custom made flexplate to make it fit. Maybe 270cdi has the same bolt pattern as 300td, then it will fit without changing flexplate.
Wut? There's no way in hell I can fit the 320cdi converter in the 606 housing for the 722.6. Did you modify something?
Or maybe a different converter because the bolt pattern on the 320 converter I have here fits the 606 flex plate.
