STD Tuning Drivetrain S/W124 722.6 gearbox mount. (Crossmember)
-Mackan-
02-11-2016, 09:13 AM #1
Hi
I reacently fitted my 722.6 auto from a 320cdi.
Is there a bolt on transmission mount for the 722.6 in the w124?
/Markus
This post was last modified: 02-11-2016, 10:12 AM by -Mackan-.
Cars currently owned:
1993 Mercedes Benz 300TDT W124
1992 Mercedes Benz 500E W124
-Mackan-
Hi
/Markus
whipplem104
02-11-2016, 09:40 AM #2
Not that I have found. I just drill the crossmember out for the transmission mount.
whipplem104
-Mackan-
02-11-2016, 09:48 AM #3
I used the wrong Word here, i meant:
Is the a "bolt on" transmission crossmember for the 722.6 trans that Will bolt up to the W/S124 chassi?
-Mackan-
whipplem104
02-11-2016, 11:50 AM #4
Like I said not that I have found. I keep looking though. No body makes an aftermarket one. I keep looking at different Mercedes.
whipplem104
-Mackan-
02-11-2016, 12:08 PM #5
Okey!
I have a w124 crossmember and a crossmember from a w210. And they are no way close to fit.
-Mackan-
Okey!
whipplem104
02-11-2016, 08:33 PM #6
It really is quite easy to just drill the holes in the 124 crossmember for the 722.6 mount.
whipplem104
jupel
03-10-2016, 12:52 PM #7
(02-11-2016, 08:33 PM)whipplem104 It really is quite easy to just drill the holes in the 124 crossmember for the 722.6 mount.
it's not comlete tip -a rear part of gearbox would be too low. because of it you need put a spasers between rear box support and crossmember
thikness is about 10-12mm
jupel
whipplem104
03-10-2016, 01:02 PM #8
Well I have never measured the drive line angle but I have done several of these and have no real vibrations to report. I also have measured the basic position to center and it seems fairly close. I also have probably around 10-20 customers with this setup in w124 chassis and have never had anyone complain.
whipplem104
Sultzi
03-10-2016, 02:05 PM #9
Just done mine, did get the driveline angle right with 320cdi gearbox mount and w124 std crossmember (300dt), just have m8 washers under the crossmember and mount to get the right height for the box. Drives nicely.
Sultzi
