STD Tuning Suspension W123 Billstein B6
W123 Billstein B6
W123 Billstein B6
R-3350
Dreaming of compounds
182
04-05-2016, 11:03 AM #1
i have been searching for some better shocks for my 85 300D finally managed to chase down the B6 sport part numbers. these are not the B4 HD shocks. Front PN:24-005289 Rear PN:24-005388 hope this helps anyone searching.
R-3350
swampmonkey
hx40 super
280
04-06-2016, 02:36 AM #2
good info, thanks!
I have b4's al around on a w123 sedan with a tad uprated engine and is very happy with those.
how is the lenght on those b6s compared to the b4? identical but the 10-15% increased damping or anything else that is good to know?
have heard that some dampers are "shorter" to cope with lowered cars etc, and my cars is just a tad lower than stock.
(il see if i can find numbers of my b4s)
daily driver
w115 240d 72hp 3.07 rearend
+ a few more.
mbturbo.com
swampmonkey
good info, thanks!
daily driver
+ a few more.
mbturbo.com
Sultzi
04-06-2016, 11:20 AM #3
B8 Bilsteins are shorter than stock, B4 are like stock and B6 should be stiffer but std lenght.
Sultzi
R-3350
182
04-06-2016, 01:41 PM #4
there the same as the b4's but i think they have the triple stage valving in them definitely better in corners than the b4 HD lose a bit on bumpy roads but i don't mind that some do some don't same loss of ride quality as going with cut sls replacement springs. now i just need a wagon front sway bar and to find out about making or adapting a heavier rear sway bar ect ect the road to a perfect car never ends
This post was last modified: 04-06-2016, 01:43 PM by R-3350.
R-3350
07-05-2016, 10:36 AM #5
You will find those are not for the W123.... Bad catalog numbers.
R-3350
182
07-06-2016, 12:49 AM #6
ya i spent some time searching they were for the w123 sedan and would have worked however they went out of production sometime in the early to mid 2000's. they were originally listed for 230's and 280's for rally use. at least thats all i could pull up. i contacted Billstein and thats what they told me. also tried anyone that listed them in stock no luck.
R-3350
