W210 200 CDI, 200-250 HP/ 450-500 Nm
I think its still less than OM613 which has 73mm3 and six cylinders but you are very close.
I don´t know. As I wrote...not full rpm.
320CDI:
https://www.youtube.com/watch?v=ECuAvosYASU
I compared your 0-180 time which is roughly 33s to my stock run and mine is 23s. 0-100 is almost the same at 8-9 seconds but in higher gear you slow down rapidly.
Take a look:
Really nice. Soon I have to make a video with higher RPMs. I think with higher RPMs is it same now
I have to make some stand for my phone - manual gearbox, only two hands
But you must have little bit more power than original...? Without catalyst, EGR...
Well after all that time invested into the engine I really hope it has at least like-new stock power. Catalyst was not clodged so it may add some MPG on casual drive but hardly any noticeable power increase. Cant wait to start playing with maps.
160-220, 5.gear till 4100rpm, winter tyres:
https://goo.gl/photos/h4aJKgbMa48sqgTLA
So, finally here is my try 0-200 km/h - 29s.
I used a stopwach on both videos
0-100:
You - 7,5s
Me - 7,6s.
0-180:
You - 21,8s
Me - 22,7s.
I think that both are pretty good. Original 320CDI 0-100: 8,3s
How is it going? In the meanwhile I got my flasher, so i remaped it. I logged with diagnostics that it is injecting 100mm3 of diesel and 2470mBar of boost. Well that should do theoreticaly 198kW. It drives like crazy.
Wow, nice numbers - go to dyno
I have to do something with turbo outlet silencer and completely block the EGR. I think there is still air leak somewhere. And after this I will go for remap. Now I am like locomotive. I want at least 250HP/500Nm. I think, It´s possible with these parts.
I installed also new bigger front brakes. 345×30mm discs. Really nice brake power.
Yes, I did away with that silencer. Well it did have some function to it, now when it boost it makes a lot of noise in IC audiable inside of car. Also mounted 550x230 FMIC right behind the grill (mounted upwards). IAT did not go above 50°C on long WOTs.
I would say that sound is anything but better. Its hissing and making all kind of airflowing related noises in that big IC.
Well I doubt that silencer had any impact on power since its inside diameter is the same that of turbine. I got rid of it because I welded on turbo to acomodate 63mm silicone hose but in your case I would leave it be and do its job. Certainly it will do no harm to power output at 200-230HP. Somewhere I read it makes sense to delete it above 300PS.
Yeah also.. since you have your injectors remanufactured thats one less thing to worry about. But talking out of experience, install EGT gauge. My happiness with car did not last long, I have melted one piston. Dont know yet if some injector let go or it melted with heat. Therefore I say EGT gauge is a must, car did not smoke so no means to know what is actually going on.
I think that the engine has now quicker response but I drove only some kilometers. Tuikku said that this silencer limits the air and power to +-300HP ...but in OM648. 300/6=50, 50*4=200HP...So, I will see.
(11-22-2016, 12:16 PM)MartinB I am driving with it. I sent video with acceleration. Little bit vibration in acceleration in about 3000-3500rpm but nothing horrible. Idling absolutely smooth.
(12-04-2016, 01:37 PM)MartinB Because of heat stress and lowering CR. Didn´t measured it. Original is 18:1 now about 16.5:1 but i don´t know.Is it smokes on idle now? Or smoke problems during wot? Because of not re-entrant bow shape, without lip. I want to lower CR on similar engine, but everyone told me that eliminate a lip not good idea because of bad air fuel mixing, not full combustion and smoke. What's your experience with lower CR and "Mexican Hat" bowl design? What about cold start? If you have problems with cold start, you can try to use glow plugs from later OM646 "Evo" engine, it's ceramic.
Few more pictures and video. Only update is bigger rear brakes. Car behaves still very nicely. Power is ~195kW, RP 1650bar, boost 2.3bar, IQ 120+mm3
Another power increase will be soon.
100-200km/h: 15,6s
Nozzles are almost out of breath and I dont see putting another 500€ in it for bigger ones so I think we will settle with round 300HP. Not to mention that modded GT23V..another €€€€.
(06-16-2017, 03:35 PM)MartinB That's huge amount of torque. Turbo is GT2564V with 11 blades?
What kind of questions are these?
(06-17-2017, 07:35 AM)MartinB Do you think that the turbo will last this boost for a long time? I was wondering for GTD2060VZ in my car. Btw 350PS is ~155mm3?
It´s not that hard to have bigger nozzles. Maybe I don´t know if I want to spend another money for another 50PS but I will see :-D
How it´s going with your ML420CDI? I bought S400CDI and can not wait for stage 1.
