w202 2.5 TD power options
I can offer chips/ ecus/ sockets.
I currently have 3 people running 180hp stage 1 ecu's for om605
and 2 with turbo upgrades with goals of 250hp from remaps that run max fuelling with minimal smoke(unlike some manual pumps) out the stock pump with no limp and boost upto 1.7bar.
Is your car auto or manual, ecu works for both.
i also have maps for 6mm/ 8mm pump om605/606
Sean
http://www.superturbodiesel.com/std/show...light=evry
Here you go, thats how to fool your ecu. But i think you should keep an eye on egt´s. Mine was pretty high depending on what resistor you use. It´s a pretty good thing to start with to increase power.
Thanks. That was the exact thread I was looking for.
I have done this mod over the weekend and it seems to be working well, giving a decent-ish boost in power that cost me around £1.20 and about an hour of my time.
The only thing now... There is a hell of a lot of smoke being thrown out the back even when on full chat and higher up in the revs which is making me think the tiny turbo cant keep up...
Is there anything that can be done to up the boost without bricking or sending my car into limp mode?
I do work for a nitrous company in the UK and I am planning to put a spare nitrous system onto the car but if I cant adjust the boost up any more then I wont get the full effect of the nitrous..
Any more info on pushing more power out of these would be great.
Thanks.
when you say 1.4, I assume you mean bar?
So as soon as the ecu see's 1.4bar it reduces my fuelling?
I think I may already be experiencing this.. If i have my throttle at about 75% (just at the start of my extra fuelling, as I have set up on a microswitch on the throttle) there seems to be a sudden boost in power and then I get the engine management light come on until I let go of the pedal.
If I go full on using kickdown and the switch for more fuel is added again then the engine management light does come on again but the car seems to maintain the higher power and smoke like crazy...
No when you put a resistor across the map sensor. The ecu sees lower boost. So reduces its fuelling. And the ecu raises the turbo boost thinking its lower.
The evry mod can only do so much. The turbo controller will be outside its range trying to maintain boost. And you'll be fuelling to much based on the airflow. The turbo can run up to 1.4bar with no smoke and make good power done properly.
But getting evry mod to do that accurately is where people give up.
Keep an eye on egt carefully. Many people have overheated and blown stock engines with stock turbos due to this.
ahh right okay I see what you mean now.
So whats the normal procedure for getting more power from these then?
I have had experience with my old 306 XUD9 which I modified with a bigger turbo and the bosch VE pump which had the internals modified and turned up. I made 196hp on the rollers with that.
Do these require more things to be changed and modified due to the ECU side?
Thanks
Ecu keeps control of everything.
You can still make good power with stock items.
But swapping turbos requires a remap to get the most.
Upper rev torque limits, limit real power gains even with very mod.
It all depends how far you want to go. Few people testing new turbos on the c250td with remaps. So expect to see some dynos or results soon. I'd imagine in the 250hp mark before putting a new pump in.
Older mechanical pumps are easier to tune but need bigger elements etc and inherently have a high cost before you choose a turbo.
If I could make 250hp, I would be more than happy but I really would have to do it all on a budget.
It will be interesting to see what these people make with testing these new turbos but yeah, If i could get it remapped and then change the turbo around and get 250, then that would be cool.
I am on an automatic box so I know that I will be limited at some point.
At the moment, I am kind of thinking about but then thinking that the money could be spent on building another car which would be half the weight of the merc but twice as fast, but I do want to give the merc a chance becase it is a nice car to drive, very comfy and quiet but the standard power really isnt good..
Thanks
Om606 is kkk k14
Om605 is a t20 / t25 variant.
Sockets and chips supplied I sell for €100 for you to fit.
These can be any map.
One of those gt2871 was sent to a turbo shop to get balanced and they said it wasn't bad at all. So could be something to consider. But they do need to have there wastegate ported.
Its something to consider without going to a hx35.
So with mine being the t25 variant, the gt2871 should be the same flange fitment right?
ahh that's not a bad price to be honest mate. So you can map to suit my needs then?
Right okay, I would possibly have a look to see if I could find a genuine garrett... I've had a few mates have some bad luck with the chinky turbos ://
I have see a few of these with the hx35's on but i'm guessing for 250hp, the holset will be a bit overkill for that power?
I had a feeling you would say that...
I used a Td04 on my old 306 which is quite a common mod for them but was pretty well suited for the 1.9.
I want useable power, the gt28xx seems like a decent sized turbo for the power I am after to be honest.
Can your maps remove the boost limiting factor then?
Yeah they run right up to the map sensor limit.
That's 1.7bar
I'm going to start using a 50psi(a) sensor on my own car when I fit my he351 hybrid and rescale so it can see up to 2.4bar then without shifting the scale too much.
Don't the 306 guys fit om606 turbos to there 1.9?
That's not too bad then.
What are the standard intercoolers good upto boost wise? And that idea with the sensor makes sense.
I think the om606 turbo on the xud was one of the upgrades people go with yeah.. They use td04, gt20's etc , been a couple moving over to vnt too.
I have now decided to take off the rack fooling mod after reading up about people having their engines go pop due to high EGT's which is exactly what I don't want. luckily, i only used it in short 5-10 second bursts, if that.. so hopefully no damage. Is this a major problem that I could run into with having a bigger turbo and more fuel going in there? Will I have to change the exhaust manifold or will a straight pipe be adequate?
Thanks
The problem with backpressure is due to the stock turbo's exhaust housing, the problem with egt is related but mainly due to the rich mixture of fuel based on airflow. if you can raise the boost for the same fuel you can lower egt.
The stock manifold is used by alot of people still and used to create decent power so its not an issue now but upto a point it is.
Some people convert to a pressure waste-gate and control boost themselves by a dawes device or electronic controller.
But youd need a remap to take advantage of that allowing for your own boost settings and also having a proper fuelling map based on boost, rather than too much like with evry mod.
okay yeah that makes sense. I don't think I will be wanting to go any more than 300hp really, so hopefully the manifold will be good for around that.
do you have any more info on your sockets and chips? I will need a run down on how to install them if I go ahead and get one from yourself. I definitely want to go ahead with this and get more power out of her though. if I can go for bigger turbo, map and nitrous combo and make good reliable power then I'll be happy.
beyond 250hp your into bigger elements in the injection pump.
I use chip-quick to de-solder the original chips and then cleanup any old solder on the contacts.
You then remove the centre from the sockets flux the contacts and solder one at at time making sure the orientation is correct and clip the chips in order.
Stage 1 is slight increase in fuel and boost but will also allow upto 1.7bar if the turbo is not ecu controlled.
Stage 2 is raised to the limit of minimal smoke from off-boost right upto 1.7bar, this map will also control the stock turbo upto about 1.3-1.4bar.
but i wouldnt use it for long with a stock turbo.
Its really for a larger turbo and will give upto 250hp without limp mode or getting to the rack limit.
this map is much different to stage 1 so people swapping turbos get the best out of there stock pump.
yeah I don't really fancy playing around with IP just yet.. I need to get to know about these cars a bit more first really.
I am familiar with soldering on boards like i mentioned with soldering on Honda ECU's, so it shouldn't be a problem.
I think the stage 2 map would be what I go for when I can sort out a turbo from somewhere. is there any chance you could allow a little more smoke boost off-boost if I needed it? I am just thinking for nitrous you see?
Also do you have any idea of where the limit is of the auto box is power and torque wise?
Just thought I would mention that I totally appreciate the help you're giving me here, even if you will be getting money off me more than likely
Thanks
I used to do hondata modules on honda ecus also and de-immo them for people doing b/16/18 swaps or tuning.
yeah stage 2 is so people can get the max without smoke, but it can be raised a little further if thats what is wanted.
Most people like a fast daily that doesnt attract too much attention.
I doubt you would need too much more fuel off boost if your planning on running nitrous though.
ahh that's cool. you obviously have a lot more experience with doing than me!
A fast daily is exactly what I'm after without attracting too much attention from the police.
Yeah, I wouldn't need a great deal more fuel off boost really, just a little bit more over the whole rev range more than likely but not too much that I would be throwing out clouds when off nitrous.
When you mentioned turbo flanges earlier... is this something I would have to fabricate or is there something that can be bought?
Youd need an adapter to go from 3bolt to t3 fitting, and this would relocate the turbo, because the steering box provides problems for people in c250td
Then youd need to redo the downpipe and run new oil lines, and extend the intercooler pipe.
I cant comment on how good the stock intercooler is but if your gaining 100hp id recommend going to an e300td (minimum) or universal style.
But its totally worth the work.
Okay, so it looks like adapting this flange is going to be a pain in the arse, I am going to have to have a look and see if I can get one made up first before I go ahead and choose a turbo.
The intercooler, new turbo oil lines and extending the intercooler pipework shouldn't be a problem to do myself.
Is there plenty of room behind the bumper for a decently sized cooler then? I assume there is?
(05-17-2016, 12:02 PM)LewisG95 This is the car I will be modifying anyway
Hi charleysays,
Thanks dude
I have just had a good read through this, I'm glad there is someone going through the same process as me at the same time.
The one thing I was mainly concerned with was the steel pipe size and where to find this 3 bolt flange, so I can't thank you enough for giving me some guidance on the size of the pipe. I do have a few local fabricators near me so hopefully they'll e able to knock me up one of those triangular flanges.
Those ebay turbo's do seem like a very decent option to go for but when I have swapped turbo's on other cars, I have always tried to go for genuine makes, Garrett, KKK, IHI etc.. There's something about the chinky turbo's that I just don't trust.
Yes! you should definitely get a project thread up. Then I can just go ahead and copy you
I'll be watching you both with your mods and tunes Lewis & Charleysays! I'm looking to do the same to my C250TD as I do a Lot of motorway driving and so I want a bit more power, 180ish seems fine though but I haven't got a clue with ECU's and soldering!
Seanyt, would the stock turbo, IP and exhaust be ok to use with your stage 1 chip?
(Not meaning to hijack your thread Lewis!).
(05-22-2016, 04:20 AM)seanyt Stage 1 is specifically for stock cars, exhaust or air filter will help a little.
But once the stock turbo is swapped then your getting into the 220-250hp mark and everything will want to flow better.
Yeah if your over I can do the ecu for you. Your stock exhaust would be fine. Especially leaving it at 180hp.
The stock turbo map is very conservative. So that can be changed to bring it in more aggressively giving you better low down torque. This is already done with stage but can be modified more if desired.
(05-22-2016, 04:58 AM)silestanix(05-22-2016, 04:20 AM)seanyt Stage 1 is specifically for stock cars, exhaust or air filter will help a little.
I'm running a K&N Panel filter (which also happened to fix a slight flat spot I had), stock exhaust however would getting rid of the back box or centre box help? Ie which would be more effective? Looking for more torque really, HP not so much just more torque for overtaking.
In addition, if I came across to Ireland, could you do the chip for me bud? I don't know anyone I can trust wih my car here except the garage I use (Wayne Gates), and I don't think they solder etc...besides I Need a holiday anyway so might as well!
Cheers btw Sean.
Cheers btw Sean.
(05-23-2016, 04:23 AM)Hario(05-22-2016, 04:58 AM)silestanix(05-22-2016, 04:20 AM)seanyt Stage 1 is specifically for stock cars, exhaust or air filter will help a little.
Cheers btw Sean.
Delete the centre silencer and cat for a noticeable difference, it's the size and weight of a suitcase. you'll have to fit a silhouette cat in the straight pipe to pass the 'visual inspection of the catalytic converter' part of the MOT though.
I did mine from clamp together 2.5" SS eBay pipe sections because hate welding zorst..
it will still be quiet if you keep the rear box mind.
Oh there's no space for a bigger IC behind the bumper, you'd have to cut out some of the front x-member and probably delete the AC condenser to get anything meaningfully bigger in there.
Cheers btw Sean.
Yes, it is combined silencer-catalyst. Personally I did not see any difference with whole OE exhasut and 63mm straight pipe. But of course with good exhaust system, that straight-five is gonna give you goose bumps-by good I do not mean pipe from turbo to bumper. Thats sad way of doing it, and you will learn your mistake soon enough.
(05-23-2016, 11:28 AM)starynovy Yes, it is combined silencer-catalyst. Personally I did not see any difference with whole OE exhasut and 63mm straight pipe. But of course with good exhaust system, that straight-five is gonna give you goose bumps-by good I do not mean pipe from turbo to bumper. Thats sad way of doing it, and you will learn your mistake soon enough.
Well, depending on condition of engine that catalyst is dead anyway might even be clodged with soot. When you replace that bottleneck turbo then maybe at some 250PS you want to get rid of back box, for now it is of least concern.
So if the middle box/cat is clogged with soot & other stuff then removing it is better surely...? Which is what H suggested...
Just want to add btw (and adding to hijacking Lewis's thread lol), I'm Not looking for over 180hp, so I won't be replacing any turbo at all.
Well for that power.. might be good checking on that catalyst if its good, if so leave it be. My car has something close to 500 000 and it was like new. Some people tend to put shit in gas tank, like oils because it will drive on it.. yes but it will fuck everything up in process including clodging your catalyst.
Ah yes. My fuel tank was dropped a month after I bought the car as I wanted to check the tank strainer but it was all good, only diesel in it and no other residue.
(05-25-2016, 12:14 PM)starynovy Well for that power.. might be good checking on that catalyst if its good, if so leave it be. My car has something close to 500 000 and it was like new. Some people tend to put shit in gas tank, like oils because it will drive on it.. yes but it will fuck everything up in process including clodging your catalyst.
(05-23-2016, 05:07 PM)silestanix(05-23-2016, 11:28 AM)starynovy Yes, it is combined silencer-catalyst. Personally I did not see any difference with whole OE exhasut and 63mm straight pipe. But of course with good exhaust system, that straight-five is gonna give you goose bumps-by good I do not mean pipe from turbo to bumper. Thats sad way of doing it, and you will learn your mistake soon enough.
Thing is, my CAT/Silencer box is 19 almost 20 years old...so I'm looking to improve things. I wouldn't remove All of the silencers, just the middle one, and I would leave the back box as standard as that section is only 1 year old. Your thoughts...?
(06-07-2016, 10:20 AM)charlysays(05-23-2016, 05:07 PM)silestanix(05-23-2016, 11:28 AM)starynovy Yes, it is combined silencer-catalyst. Personally I did not see any difference with whole OE exhasut and 63mm straight pipe. But of course with good exhaust system, that straight-five is gonna give you goose bumps-by good I do not mean pipe from turbo to bumper. Thats sad way of doing it, and you will learn your mistake soon enough.
That is what I did and I would recommend it.
The back box adds little restriction, the middle box/ Cat. certainly does.
Replace it with a piece of straight pipe.
If there ever comes a time when not having a cat. on an old diesel will cause an MOT failure, you can weld it back in and it will be in better condition than if you'd left it on the car.
(06-08-2016, 12:00 AM)silestanix(06-07-2016, 10:20 AM)charlysays(05-23-2016, 05:07 PM)silestanix Thing is, my CAT/Silencer box is 19 almost 20 years old...so I'm looking to improve things. I wouldn't remove All of the silencers, just the middle one, and I would leave the back box as standard as that section is only 1 year old. Your thoughts...?
This is what I thought. I'd keep the backbox as I still want the car to have reasonable comfort and quietness. If my MOT tester ever leaves then I'll just get it welded in at MOT time or leave flanges on each end so I can add/remove it when required.
