STD Tuning Engine variety of OM617 tachs
bricktron
'77 240D
174
05-09-2016, 09:32 PM #1
hi folks, i was butchering a five-cyl tach to convert it when i noticed that the other one i had on hand was different. the VDO part numbers differ as do the signal jacks and circuitboards.
the numbers visible on the two tachs are: 230/154/1 14000Hz, on the one i was cutting up; and 230/107/15  6000Imp., on the one from a cluster which is elsewhere stamped 1982. unfortunately i don't know where the butchered one came from.
do these two units work the same? the numbers 6000 and 14000 sure make me wonder.
cheers!
[Image: tachs.jpg]
bricktron
cheers!
[Image: tachs.jpg]
NZScott
HX30W 73/44mm
398
05-10-2016, 04:00 PM #2
The one with 14000 is meant for '84-'85 cars with EGR computer. They had a VR sensor on the flywheel with ran off the starter ring teeth. You can bypass the EGR computer however.
I imported one of those, and bought a VR sensor (for a 6BT) myself but haven't quite got to the stage of seeing if it actually works yet...
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
bricktron
'77 240D
174
05-17-2016, 07:50 PM #3
thanks Scott! since i don't have the flywheel sensor, i guess i need an older tach.... cut up the wrong one. onwards and upwards!
bricktron
EvoPeter
05-20-2016, 04:35 PM #4
If i remember correct i took a w124 or w201 diesel tacho and installed it in the w123 cluster 1 year ago. Had an om606 in that car from a w124. Only drove some km with it before i sold it.
EvoPeter
