STD Tuning Drivetrain Gearbox info
Gearbox info
Gearbox info
190Gilly
05-23-2016, 09:56 AM #1
Looking for some info on my gearbox.
Pulled from an e300 '97/'98. Part numbers are:
R210 271 09 01
Is this in any way a desirable box? I've seen the '722.6' box mentioned a lot, is this similar or am I missing a part number on there somewhere? Or are they completely different?
Either way it will be for sale shortly!
Cheers
190Gilly
R210 271 09 01
Cheers
Evgeniy1987
05-23-2016, 11:26 AM #2
Can you see more numbers on the gearbox? It is indeed a "722.6" one, but there are some different types of "722.6"
Evgeniy1987
190Gilly
05-23-2016, 11:53 AM #3
(05-23-2016, 11:26 AM)Evgeniy1987 Can you see more numbers on the gearbox? It is indeed a "722.6" one, but there are some different types of "722.6"
I've got 32 5234 00 I think, and 1 2828 f7, and r 140 271 26 01. That's all I could see yesterday, will there be a definitive 722.6xx somewhere?
190Gilly
Evgeniy1987
05-23-2016, 12:07 PM #4
http://www.all-trans.by/assets/site/file...22.6.1.pdf
Have a look there, it might help Smile
Evgeniy1987
seanyt
is300d He351ve
279
05-24-2016, 03:23 AM #5
If it was pulled from a running/driving w210 e300.
Then its a nag small, otherwise it would of had code from 3 incorrect ratio gears.
Larger cdi and v8 cars all have the stronger nag large box.
Nag small is found in older diesels and the petrols smaller than v8.
seanyt
ross
05-24-2016, 05:11 AM #6
Theres a small flat area on the LH (looking from the rear) of the box that will have the 722.6XX number stamped into it.
ross
190Gilly
05-24-2016, 05:14 AM #7
Thank you, I'll have to check next time I get to where I'm keeping it. Either way it'l be for sale as I say! Cheers
190Gilly
 7 Guest(s)
 7 Guest(s)
