STD Tuning Engine OM617 NA - Garrett T25 - big enough?
Dusty-G
05-25-2016, 08:17 PM #1
Hi
This engine is in a Gwagen, and it was turbo-ed years ago. I have rebuilt the engine, but unfortunately the turbo is leaking internally.
Before rebuilding the turbo, I want to hear the opinions of Others on whether this turbo is OK for this engine? I realize that there is also the question of what impeller is in there (trim?), but as I will be looking at replacing the impeller/shaft anyway, I would like to know if this is a feasible choice. I never got to drive the car, so have no idea if the original installation worked well or not.
The reason I ask is that the factory OM617A uses a larger T3 - size.
Thanks
Adrian
Dusty-G
Hi
Thanks
Adrian
NZScott
HX30W 73/44mm
398
05-25-2016, 08:47 PM #2
If anything, you want bigger...
I went small for my NA>turbo conversion and changed my mind - small turbine means high EMP and EGT which will stress the engine more.
Have a read of http://www.4btswaps.com/forum/showthread...nce-Review
Edit: I'll just add, I see no point sticking with 40 year old turbo designs, if that's what you've got. Get something more modern if you can.
This post was last modified: 05-25-2016, 08:48 PM by NZScott.
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
05-26-2016, 04:25 AM #3
anything from a OEM 3 liter diesel... can do the job... expecially one less than 20 years ago... like the kkk24
Dusty-G
05-29-2016, 07:51 AM #4
(05-26-2016, 04:25 AM)barrote anything from a OEM 3 liter diesel... can do the job... expecially one less than 20 years ago... like the kkk24
Yes, good point. I am investigating a few options here. This installation set the turbo towards the rear of the engine, where its heat has affected the steering column in the past...
Thanks for the responses.
Dusty-G
