STD Tuning Engine om606 in w211
om606 in w211
om606 in w211
street_666
Hx55
42
05-27-2016, 06:19 AM #1
hi
do anyone know how?
do i need only fool the ecu or more?
and its anyone on forum can do that or you know anyone (ex. dpumpuk)
street_666
hi
do anyone know how?
NiTeC
05-27-2016, 09:12 PM #2
(05-27-2016, 06:19 AM)street_666 hi
do anyone know how?
I am looking into the same thing...the 211s here are either V6 or V8 so it may require custom mounts but there are I6 diesels offered in the 211 body in EU right?
NiTeC
do anyone know how?
seanyt
is300d He351ve
279
05-28-2016, 03:17 AM #3
I'd imagine, stock cdi ecu is used but remapped to get rid of DTC (error codes)
Sprinter flywheel. Because it has the correct trigger wheel.
Mechanical fuel pump.
320cdi sump and oil pump.
seanyt
street_666
Hx55
42
05-28-2016, 03:08 PM #4
(05-27-2016, 09:12 PM)NiTeC
do anyone know how?
(05-28-2016, 03:17 AM)seanyt I'd imagine, stock cdi ecu is used but remapped to get rid of DTC (error codes)
yes NiTeC i wanna make an om606 of course so its bolt on.
i wanna buy an e270 avangarde in manual
street_666
do anyone know how?
seanyt
is300d He351ve
279
05-28-2016, 03:13 PM #5
V6 and v8 may also work. Once they don't have cam sensors.
You just need the ecu to see crank, coolant.
To relay to the clocks. Abs will run the esp and abs once you go manual.
This post was last modified: 05-28-2016, 03:40 PM by seanyt.
seanyt
street_666
Hx55
42
05-30-2016, 11:47 PM #6
Do can i edit the ecu by kwp2000 and disable dtc errors?
street_666
MartinB
OM605 Power
154
05-31-2016, 09:10 AM #7
No. KWP2000 is only flasher but not for EDC16
MartinB
starynovy
05-31-2016, 02:29 PM #8
Also it is not as easy "I connect here and find DTC propertly named in list and clicky click I disable them".  Big Grin
starynovy
street_666
Hx55
42
06-01-2016, 12:49 AM #9
So what equipment of Who should i look for it ?
street_666
06-03-2016, 10:52 AM #10
I think you will want the E320cdi engine mounts. The 270 is 5 cylinder and wil move the engine relative to the gearbox.
I expect the 606 crank sensor will drive the stock w211 tack.
603 IP or 606EDC & ole is simplest in my 'unable to modify ECU' eyes..
I think the 211 has 722.6 or if not it will definitely fit on the mounts.
street_666
Hx55
42
06-03-2016, 01:30 PM #11
i have a w210  606 and i wanna swap it to spare 602 and then 606 goes to e270cdi manual combi and sell the 612
street_666
seanyt
is300d He351ve
279
06-03-2016, 02:26 PM #12
The instrument cluster is canbus so on a w211, it will want to talk to a w211 ecu for tacho and everything else so a w211 flex plate will only do.
Om606 edc ecu won't drive a w211 instrument cluster, nearly sure the canbus pid are different. They both use canbus to relay information though.
If your set on w211 then use stock ecu and flex plate. With mechanical pump. Or use a om606 flex plate and ecu and find out the canbus pid's and put them through a canbus controller to change there pid. Harder but possible, then sell it so its easy for everyone to do haha.
seanyt
street_666
Hx55
42
06-03-2016, 05:17 PM #13
(06-03-2016, 02:26 PM)seanyt The instrument cluster is canbus so on a w211, it will want to talk to a w211 ecu for tacho and everything else so a w211 flex plate will only do.
I prefer mechanical pump because i am not a advanced electrician.
And till now i dont know how disable those dtc errors from engine!!!!
I need only spedo, temp,rpm,charging and thats all i think.
Do i need teplace chips like on w210 or buy custom ecu or go pro tuner but last gonna be expensive in poland.
street_666
seanyt
is300d He351ve
279
06-03-2016, 05:28 PM #14
If it was me for the sake of simplicity I'd fit 606 with mechanical pump and w211 flex plate.
Use the old loom and temp sensors etc.
This should give you tacho, temp, battery. Speed is from abs ecu.
Then read the error codes and get a tuner to remove them in one go.
A good tuner will just wipe all DTC for you from ecu.
Ole controller will deal with gearbox then if using auto.
seanyt
street_666
Hx55
42
06-04-2016, 04:00 AM #15
Are tuned chips already to solder in? When yes who sell dose?
I wanna a make a much a possible by my self!
street_666
seanyt
is300d He351ve
279
06-04-2016, 04:02 AM #16
No you bring the ecu to a tuner
seanyt
06-07-2016, 02:56 PM #17
5 & 6 cylinder doesn't use 5 or 6 tag flexdisc pickups like 605 /6 ?
Petar
7.5mm M pump
459
06-07-2016, 04:31 PM #18
No, cdi pickups have like 40-50 tooth pickup with 2 missing for tdc mark
Petar
seanyt
is300d He351ve
279
06-07-2016, 05:08 PM #19
60-2 is the norm for bosch trigger wheels on common rail and most petrol.
Although petrol's change and have cam sensors also.
seanyt
street_666
Hx55
42
06-12-2016, 09:14 AM #20
And what if I buy a automatic one and switch to manual zf bmw there some errors apears?
street_666
starynovy
06-14-2016, 04:35 AM #21
Without TCU in place it wont even start.
starynovy
seanyt
is300d He351ve
279
06-14-2016, 04:47 AM #22
May not start directly from key , but an om606 ecu will start all day long in any vehicle. Once chipped and immo'd
seanyt
 9 Guest(s)
 9 Guest(s)
