STD Other Projects L200 om605
L200 om605
L200 om605
Mallinman
06-27-2016, 04:21 PM #1
Got fed up off the crappy jap engine in my l200 truck exploding. So I'm putting the 605 in. Got a pump  ordered from Sweden and I'm hoping for just over 300hp from it. Can't decide on what turbo yet. Want a quick spooling one for low down power for towing and off-roading. Any suggestions??  I've just about finished the adapter  plate as its goin on to a manual box. Then it's off for a custom flywheel and clutch to mate it all together.  Goin to be a daily driver 2 so should be fun. Any oNe know where I can get a 605 engine manual from?? Il get some pics up when I can figure out how. It says there 2 big to attach.
Mitsubishi L200 manual om605
7.5mm Bosch 044 fed pump
Borgwarner S200
Mallinman
Borgwarner S200
06-28-2016, 06:23 AM #2
What about a Haynes manual? I've got some Mercedes workshop manual pictures in my photo bucket
[Image: 230.jpg]
This post was last modified: 06-28-2016, 06:23 AM by Hario'.
[Image: 230.jpg]
Mallinman
06-28-2016, 04:55 PM #3
Never thought of that tbh. Been used to having trucks that they don't do them for.
Borgwarner S200
Mallinman
Borgwarner S200
Mallinman
07-03-2016, 04:40 PM #4
Engine mounts done today. It's all in. Adapter plate fits perfect. Now just for all the rest of the stuff to do.
Borgwarner S200
Mallinman
Borgwarner S200
Mallinman
07-04-2016, 04:34 PM #5
Still undecided on what turbo set up to use. Anyone got any ideas or info on what they use??
How do I upload pictures on here??
Borgwarner S200
Mallinman
Borgwarner S200
street_666
Hx55
42
07-05-2016, 01:54 AM #6
i have a custom bulid hx 40 whit 6cm ex housing
street_666
EDH_Performance
07-05-2016, 02:53 PM #7
(07-05-2016, 01:54 AM)street_666 i have a custom bulid hx 40 whit 6cm ex housing
6 cm?
EDH_Performance
6 cm?
street_666
Hx55
42
07-05-2016, 03:47 PM #8
6cm2 housing
street_666
6cm2 housing
EDH_Performance
07-06-2016, 05:18 AM #9
(07-05-2016, 03:47 PM)street_666 6cm2 housing
Cool, do you have a picture? Ive made one with ~8cm once...
EDH_Performance
street_666
Hx55
42
07-06-2016, 11:50 AM #10
one is enough
street_666
one is enough
STDGer
07-06-2016, 04:44 PM #11
This will Run very hot. U dont get scared by egp??
STDGer
Mallinman
07-07-2016, 04:55 PM #12
(07-06-2016, 04:44 PM)STDGer This will Run very hot. U dont get scared by egp??
Wat will run very hot??
Borgwarner S200
Mallinman
Borgwarner S200
STDGer
07-09-2016, 05:19 PM #13
Egt? Wouldnt rev such a turbo above 4 k
STDGer
Mallinman
07-18-2016, 04:33 PM #14
Glow plugs drilled out and pulled out today after they all snapped off. New ones finally in. Water pump drilled out and threaded for extra cooling pipe to the back of the block.
Turbos off being bored out and a bigger compressor wheel in.
Just waiting on the flywheel now. Just need more time to crack on with it.
Borgwarner S200
Mallinman
Borgwarner S200
Mallinman
09-05-2016, 01:01 PM #15
Anyone ever had any problems with the throttle lever on dieselmeken pumps catching on the cylinder head or have I just done something very stupid on the pump install??
Borgwarner S200
Mallinman
Borgwarner S200
Mallinman
09-05-2016, 02:32 PM #16
Scrap the last post. Had a proper dumb ass moment.
Borgwarner S200
Mallinman
Borgwarner S200
baldur
Fast
509
09-05-2016, 07:40 PM #17
Oh yeah those jap diesels are proper junk. It's like they're not even trying. Toyota, Mitsubishi, Nissan, all of them have horrible underpowered unreliable inefficient pieces of junk for diesels. Only exception I know of for Toyota is a Land Cruiser that came with an engine built by Yanmar, so the only Toyota diesel that works isn't actually by Toyota. And get this, my korean truck with a 30 year old Mercedes designed engine gets far better fuel mileage than Toyota diesel trucks made in this century.
You won't regret doing that swap!
This post was last modified: 09-05-2016, 07:41 PM by baldur.
Baldur Gislason
baldur
Baldur Gislason
Mallinman
10-01-2016, 01:01 PM #18
Borgwarner S200
Mallinman
Borgwarner S200
bigblue
mostly legal
8
10-07-2016, 02:28 PM #19
(09-05-2016, 07:40 PM)baldur Oh yeah those jap diesels are proper junk. It's like they're not even trying. Toyota, Mitsubishi, Nissan, all of them have horrible underpowered unreliable inefficient pieces of junk for diesels. Only exception I know of for Toyota is a Land Cruiser that came with an engine built by Yanmar, so the only Toyota diesel that works isn't actually by Toyota. And get this, my korean truck with a 30 year old Mercedes designed engine gets far better fuel mileage than Toyota diesel trucks made in this century.
I've got a 2002 Isuzu 4HE1 which has been incredibly reliable in the 6 years I have run a business requiring it.  And underpowered. And inefficient.  Kinda what you'd expect from a 1980s japanese gas motor.
1999 w210 e300
2006 w211 e320 cdi
2003 VW jetta ALH
2004 VW r32 PD150
bigblue
1999 w210 e300
2006 w211 e320 cdi
2003 VW jetta ALH
2004 VW r32 PD150
NZScott
HX30W 73/44mm
398
10-07-2016, 09:23 PM #20
*thread hijack*
Why do I never see Jap auto diesels putting out the power MB diesels can? I hate to call them crap but TD42s and 1HD-T etc never ever get up to 500+...ok they're larger engines so can't rev as high but won't the extra torque make up for it like a 6BT etc. RD28T, 4D56T even seem to break stuff on stock power
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
*thread hijack*
1981 240D 498,000
1975 HJ45 ???,000
Mallinman
12-26-2016, 03:03 PM #21
Got the engine running today. Just a quick test to see if it runs ok before the final install. I've not heard it run yet. Just wanted to make sure all cylinders were firing ok with the new pump. No coolant in so only a 10sec run.
https://youtu.be/WWJJZyYr2fc
Borgwarner S200
Mallinman
Borgwarner S200
01-22-2017, 06:36 AM #22
(07-04-2016, 04:34 PM)Mallinman Still undecided on what turbo set up to use. Anyone got any ideas or info on what they use??
If you're going for cheap then perhaps a HY35, from a 12v Dodge Ram. I got one shipped from US for less than $100 all in.
maxypriest
01-22-2017, 02:36 PM #23
(12-26-2016, 03:03 PM)Mallinman Got the engine running today. Just a quick test to see if it runs ok before the final install. I've not heard it run yet. Just wanted to make sure all cylinders were firing ok with the new pump.  No coolant in so only a 10sec run.
Good progress !
maxypriest
Good progress !
Mallinman
01-22-2017, 03:07 PM #24
I've got the standard 605 turbo on at the mo. It's Been rebuilt and had a bigger comp wheel put in. Put the same turbine wheel in to keep the fast spool. It's at about 24psi at the mo. Il run this set up for a bit then I might change to a hx30 or 35. I could just do with fast spool as I want low down torque for 4x4.
Borgwarner S200
Mallinman
Borgwarner S200
Mallinman
05-17-2017, 02:30 PM #25
http://i1378.photobucket.com/albums/ah10...cwtpo4.jpg
This is a link to the photo bucket album build for the truck.
This post was last modified: 05-17-2017, 02:35 PM by Mallinman.
Borgwarner S200
Mallinman
Borgwarner S200
05-17-2017, 04:47 PM #26
[Image: IMG_1788_zpsaqcwtpo4.jpg]
There you go. (Copy & paste the 'IMG' link on the right hand side of the page where this photo is in the Photobucket webpage).
This post was last modified: 05-17-2017, 04:48 PM by Hario'.
X Double Dot
05-17-2017, 09:03 PM #27
great build, love the way you cut the bellhousing flange with the angle grinder "fixture". Also nice welds on that thing.
X Double Dot
Mallinman
05-18-2017, 07:27 AM #28
Cheers bud. Il get some photos put on so it's not just a link. Now I know how to do it. Thanx for the advise Hario
Borgwarner S200
Mallinman
Borgwarner S200
Mallinman
06-07-2017, 03:25 PM #29
http://rs1378.pbsrc.com/albums/ah102/Mal...0&fit=clip
Borgwarner S200
Mallinman
Borgwarner S200
Mallinman
06-07-2017, 03:33 PM #30
ive got the standard turbo in my 605. But rebuilt with a t28 wheel. It's giving me nice spool up and I've capped it at 25psi. But it's running out at higher revs. Im thinking of a compound setup with the my current turbo and a hx35. Im worried a hx35 alone will give me a slow spool up. But put with my turbo now should give great spool and give good flow top end. The truck moves very well as it is but I want a bit more. And it's smoking top end so obviously needs more air. Any thoughts on this combo
Borgwarner S200
Mallinman
Borgwarner S200
Mallinman
06-30-2017, 08:53 AM #31
https://youtu.be/kpoRxKJ2p9w
Not too bad for a 2 tonne truck
Borgwarner S200
Mallinman
Borgwarner S200
maxypriest
07-04-2017, 07:21 AM #32
Most excellent! Infinitely better that the original unit.
maxypriest
606110
07-08-2017, 04:17 PM #33
Never driven an L200 but bet it's an improvement! Looking at a compound 606 setup in a Defender engine bay, seems compound setups are pretty rare in the UK.
606110
Mallinman
07-09-2017, 09:50 AM #34
There's one with a turbo and supercharger on it. But that's in a disco. There's not many good conversions around. I knows kid who's put a 606 in his l200. But he had to chop a lot away at the front to fit it in. He's only running standard turbo tho.
Borgwarner S200
Mallinman
Borgwarner S200
Mallinman
05-13-2018, 10:03 AM #35
Going to finish off the turbo manifold over the next couple of weeks and want to get peoples thoughts on wastegates. Do I want an internal or external. What are the pros and cons of each. I going to run a hybrid turbo. It’s a hx35 compressor wheel and housing mated with a Garret .48AR turbine housing. I’m trying not to get too much lag. Just after any opinions or feedback of what other people have. Good or bad. Whilst I’m welding it all up it would be easier to know to go external or not.
Borgwarner S200
Mallinman
Borgwarner S200
 21 Guest(s)
 21 Guest(s)
