STD Other Non MBZ Diesel MTDI Bosch VE won't shut off
Fishman
07-08-2016, 12:56 PM #1
Hi,
I've build a mechanical Bosch VE pump for a 2.5 R5 TDI. Basepump is a Rover Mechanical TDI pump. Engine runs great, but when i want to shut her off, she keeps running irregular. Pump is tested, nozzels are tested en stopselenoid is tested. All ok. Anybody a idea what's wrong?
This post was last modified: 07-08-2016, 12:57 PM by Fishman.
Fishman
Hi,
07-08-2016, 05:41 PM #2
the pump should shut off when 12v is taken away from the solenoid. Do you have voltage at the solenoid when it's shutoff?
Fishman
07-09-2016, 02:13 AM #3
No voltage at de cut off valve. I can disconnect the batterie an she keeps running.
Fishman
07-10-2016, 07:36 AM #4
Hmmm, that is interesting. Are all the parts and pieces in the shutoff solenoid?
Fishman
07-10-2016, 08:06 AM #5
Yess. Even fitted an other one.
Fishman
07-10-2016, 04:37 PM #6
Any picture of the pump? There are several different styles of VE pumps,
Some I have seen have mechanical stops
Petar
7.5mm M pump
459
07-10-2016, 05:48 PM #7
[Image: clip_image002_thumb.jpg?imgmax=800]
From what i can see your problem is either the stop solenoid, or there is another hole that the fuel goes through, or the seat of the valve leaks. Maybe you have the push type solenoid ? Have you tried applying power to shut it down ?
Petar
Evgeniy1987
07-12-2016, 07:54 AM #8
The pump makes too high pressure. The distance between the pumping element piston and the "end screw" is too little. increase the distance by installing a thinner shim between the camplate and piston..
That is a very common cause of such problem.
Evgeniy1987
Fishman
07-16-2016, 03:45 AM #9
(07-12-2016, 07:54 AM)Evgeniy1987 The pump makes too high pressure. The distance between the pumping element piston and the "end screw" is too little. increase the distance by installing a thinner shim between the camplate and piston..
I had the pressure tested and it was way to low. They shimmed it to a higher pressure. Before i didn't get any black diesel smoke. Now i do. I can shut it off with the mechanical lever.
https://youtu.be/LFRPp4YUtiM
[Image: 20160302_151332_zpsyg2nzkyc.jpg]
This post was last modified: 07-16-2016, 03:53 AM by Fishman.
Fishman
starynovy
07-18-2016, 05:45 AM #10
Wow, not common to see mechanical pump with injection advance selenoid.
starynovy
