STD Tuning Engine OM606.962 factory E-pump performance specs.
50harleyrider
GTA2359VK
397
07-14-2016, 08:34 AM #1
Is there any published data out there for measuring the E-pumps' scavenging pump requirements? I need to know the suction negative pressure it produces to pull fuel from the tank and the head it produces inside the IP. The IP does have a return line so there must be a regulator inside the IP. Where I'm going with this is determining the need for a lift pump for a modest 100 HP increase over stock even if I have to have Dieselmeken put larger elements in my E-pump. The w210 has no lift pump so the scavenging pump does all the suction and return work, I guess. I know the e-pump in my VE-TDI is still functioning fine even doubling the HP.
This post was last modified: 07-14-2016, 08:36 AM by 50harleyrider.
50harleyrider
07-14-2016, 09:22 AM #2
It is a reciprocating piston hydraulic pump, same as used in pressure washers and old school hydraulic pumps so head or pressure isn't going to be a problem.
There is a sprung 'pressure release' valve in the return line banjo on the side of the IP, fitting a longer/stiffer spring is a realistic upgrade for that.
Loads of suction hence bubbles in all worn out W210 feed lines.
just my €2..
just my €2..
07-14-2016, 02:18 PM #3
the information asked above is not available anywhere,
The M EDC pump working principle is the same as the other M inline pumps!
Fuel enters the main galery through positive pressure , the element plunguer produces a very small negative pressure inside the cylinder when going dwn enough to fill the cylinder, upon going up the cylinder is sealed and the injection quantity is determined by the helix release pressure.
if the main galery is suplied with more than .5 bar the return banjo wich incorporates a relief pressure valve, will allow the return flow back to the tank.
The positive pressure can either be supplied by what is commonly referred as "lift pump" or by an in tank "boost pump"
is not common to find a inline pump able to work without some level of positive pressure in the main gallery.
VE pumps and other alike incorporate a pull pump inside (is baffle pump) a way more stronguer than any lift pump available for a inline pump, just cause this pull pump will be able to build interstage pressure wich can go as high as 9 bar, this interstage pressure is used at least for the advance mechanism , among other featutres.(and is regulated)
even if we fit a 14mm rotor head to a VE it will still produces enough interstage pressure at high idle, and therefore enough flow ...
when a dieselmeken element is installed in a M type pump , in some cases at least 1.5 bar in the main gallery is a must otherwise the pump will limp at high rpm and high load, and in this case the banjo pressure relief valve has to be changed to a one at 1.5 bar rating.
hope u be clarified...
regards
regards
AlanMcR
mind - blown
400
07-14-2016, 11:14 PM #4
Are there alternate pressure relief valves for the EDC pump?
The original has a plastic valve and a rather fragile spring, and fails after not too long.
After finding the failed valve, I installed a 2mm (going from memory) orifice into the exit. This transfers the pressure regulation function to the lift pump. The pump can only pressurize the galley to the extent that the internal return spring can push the pump plunger.
AlanMcR
07-14-2016, 11:55 PM #5
unfortunatly , the original valve is mean´t to bleed air in the main gallery, and promote filling at positive pressure.
the lift pump by itself wont pressurize too much even if one closes the exit port.
There many other pumps with return banjos with valves , wich can be used in the M, like the ones in the Lucas rotary pumps wich have the same thread and the valve is a metal sphere wich can be modded in pressure by changing the spring.
or ebay...
or ebay...
AlanMcR
mind - blown
400
07-15-2016, 11:29 AM #6
If the lift pump isn't pressurizing the galley, what is? It is a spring driven fuel pump just like any other.
I recall that the EDC pump had a weird thread not found on most of the other MB pumps.
AlanMcR
07-15-2016, 12:40 PM #7
well,
i wrote that the banjo valve is .5 bar , the pressure in the main gallery is very low. take it as u want it.
well,
50harleyrider
GTA2359VK
397
07-16-2016, 07:41 AM #8
Ok, so what I'm hearing here is it would be nothing but helpful to put a lift pump to supply my E injection pump. I plan to use the factory Ford gas lift pump and regulate it down to 1 bar with a non-return (dead head) type regulator. I have to do some investigation if it would wear out the lift pump running constantly. I can just use the MB return line into the F-150 return line. Also regulator manufacturers do no comment to me on the effect of biodiesel on their diaphragms.  Thanks for all the input.
This post was last modified: 07-16-2016, 07:43 AM by 50harleyrider.
50harleyrider
bruno_pinho
07-16-2016, 09:28 AM #9
I use a boosh 044 feed pump to supply my EDC pump ...
Regulated 1 bar without boost and 3 bar with boost....
bruno_pinho
50harleyrider
GTA2359VK
397
07-17-2016, 09:07 AM #10
The factory Ford lift pump delivers 2-3 bar (28-45 psig) with the engine running. Do I need to even regulate that on the E-pump? I would love to know suction pressures the e-pump can handle and still function and return fuel to the tank. From what barrote is saying in post #3, for anything over 1/2 bar or 7 psig, it will just return and should be fine. Everyone agree?
This post was last modified: 07-17-2016, 09:09 AM by 50harleyrider.
50harleyrider
Petar
7.5mm M pump
459
07-17-2016, 10:07 AM #11
I don't know if the return flow banjo can flow enough but the lift pump will flow as much as you want by design, even with the engine stopped.
Petar
 7 Guest(s)
 7 Guest(s)
