STD Maintenance General Oil cooler stripped threads!
EmJay
07-14-2016, 09:35 PM #1
Help!  I was doing a routine oil change and decided to replace my oil cooler hoses as they were leaking pretty bad.  I took the two fittings off the filter housing OK, and the lower fitting on the colder no problem.  The upper one though was harder to turn though and I found out why.  Gotta love it when previous owner cross threads an important connection.
[Image: IMG_20160714_222009928_zpsi8nqq4l2.jpg]
So my question, is the fitting in the cooler a serviceable fitting (IE replaceable) or do I need to source another cooler?  There are two 300Ds in my PaP weight the coolers in place.
This post was last modified: 07-14-2016, 09:36 PM by EmJay.
EmJay
NZScott
HX30W 73/44mm
398
07-14-2016, 11:16 PM #2
I had this same problem recently,
I took the steel fitting out of the oil filter housing on my spare engine and got a machine shop to cut the cooler threads off and tap the hole 18x1.5.
Bingo fixed. My cooler still sitting in the back seat of my toyota since I picked it up though Wink
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
EmJay
07-15-2016, 05:26 AM #3
At the threaded fitting in the cooler comes out easily? I was afraid to try and to mess it up worse. Guess I can get just the fitting from a junkyard part then.
EmJay
EmJay
07-15-2016, 09:18 PM #4
Ok so I got lucky as hell, it looks worse than it is. I was able to chase the threads with a thread file, and clean the stripped material from the nut. Goes on hand tight easy now. Wondering if I should use antisieze or JB weld. I know the next time that cooler line comes off that fitting probably will need replacing.
EmJay
NZScott
HX30W 73/44mm
398
07-16-2016, 12:58 AM #5
Ah, well then. Hopefully it holds together...something like that wouldn't hurt
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
07-16-2016, 04:43 PM #6
Just get the large sized tap and die kit from Norther Tool and run a die over it. That will clean up the threads.
EmJay
07-16-2016, 10:28 PM #7
Any chance you know the thread size and pitch? Might be something that I look at the next oil change. I put the car back together today, I used antisieze on all the threads. Everything went on tight and no leaks! Now to figure out my weird vibration issue when/after braking. Keeping an eye on it over the next several days, put ~50 miles on it today without issue.
EmJay
Austincarnut
07-17-2016, 04:07 PM #8
(07-16-2016, 10:28 PM)i have  spares if you want another cooler EmJay Any chance you know the thread size and pitch?  Might be something that I look at the next oil change.  I put the car back together today, I used antisieze on all the threads.  Everything went on tight and no leaks!  Now to figure out my weird vibration issue when/after braking.  Keeping an eye on it over the next several days, put ~50 miles on it today without issue.
Austincarnut
EmJay
07-17-2016, 09:42 PM #9
Might be interested for a later date, I believe that I'm set for now.
EmJay
07-24-2016, 08:19 PM #10
I had aluminium barb fittings welded onto mine, works great. No way the hoses could come off
EmJay
07-25-2016, 08:58 PM #11
Pleased to say that a few hundred miles later still good on the cooler.
EmJay
07-26-2016, 01:54 PM #12
I don't remember, but I will try to figure it out once the heat wave breaks ... my garage is an oven right now.
EmJay
07-27-2016, 05:35 AM #13
Oh I understand man, it has been 90+ here as well for over 50 days. Glad I have AC in this one
EmJay
martureo
07-28-2016, 02:57 PM #14
It's a little late now, but in trying to find material to repair a 603 oil cooler I found this gem.
http://peachparts.com/shopforum/members/...apair.html
(you'll need to login to see it)
The jist is that apparently Mercedes was aware of the threads stripping and created a solution. Cut off the threads and drill the hex portion of the oil cooler 21/32 for a M18 x 1.50mm tap. Tap the hole and use MBZ p/n 915013-013002 thread replacement adaptor.
I've called my dealer and the price is ~$5 each.
1983 300TD
1984 300D
1995 E300 (sold)
martureo
1983 300TD
1984 300D
1995 E300 (sold)
EmJay
08-01-2016, 09:25 PM #15
Thanks!  This is awesome, and now on this forum we have an answer that is easily searched for.  Great find!
EmJay
