STD Other FS / WTB / Buying guides WTB: Bellhousing for Getrag 265 for 190E 2.3-16 "Cosworth"
mike89011
08-19-2016, 07:59 PM #1
Let me know!
Thanks!
mike89011
Let me know!
Thanks!
EmJay
08-19-2016, 09:52 PM #2
Curious, what are you attempting to do?
EmJay
hents99
08-20-2016, 06:54 AM #3
190E 16V Getrag (275) Bellhousing is not removable.
BMW/Jaguar/Opel Getrag (265 both close ratio and overdrive) bellhousings are removable.
www.elbe.ee - MB performance parts.
hents99
mike89011
08-25-2016, 08:50 AM #4
(08-19-2016, 09:52 PM)EmJay Curious, what are you attempting to do?
I would like to put a Getrag 265/6 behind an OM606, but since the BMW bellhousing is different, will need the Cosworth bellhousing
(08-20-2016, 06:54 AM)hents99 190E 16V Getrag (275) Bellhousing is not removable.
Is part number 0002601411 not a bellhousing?
Can someone else confirm that the Cosworth Getrag 265 does not have a removable bellhousing?
Is seems odd that all the other Getrag 265 applications would use a removal bellhousing, except Mercedes?
mike89011
08-25-2016, 09:30 AM #5
Common misconception that the 16v trans is a 265. It's a 275.[Image: 10556221_10152613106960498_3873700170010...e=5844568C]
This post was last modified: 08-25-2016, 09:32 AM by raysorenson.
mike89011
08-26-2016, 04:37 AM #6
Well that photo seems fairly definitive to me!!
Isn't that something, how everybody talks about the 190E Cosworth having the close ratio Getrag 265 (i.e. Getrag 265/5), when it actually has something totally different!
Thanks for clarifying!
mike89011
Austincarnut
08-27-2016, 03:46 PM #7
(08-25-2016, 08:50 AM)could you use a 240d bell housing?  I mated a getrag 265 to my 617!  it made all the difference in the world to drive  mike89011
This post was last modified: 08-27-2016, 03:46 PM by Austincarnut.
Austincarnut
hents99
08-29-2016, 09:02 AM #8
OM617 has different bell housing. Starter is other side of engine. Not left side but right side. You can`t use with OM606.
hents99
NZScott
HX30W 73/44mm
398
08-29-2016, 03:30 PM #9
I don't know of any MB Getrags with separate bell housings. Only the older iron box jobs.
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
