STD Tuning Drivetrain 5 speed 300sd m110 flywheel clutch opitions help!
300sd/5speed
09-17-2016, 07:33 AM #1
Hi people I'm new the forum!
My issue is I converted my 79 300sd to A 5 speed manual from a 300d using an m110  280se flywheel the problem is the stock m110 clutch won't hold the torque from the modified  om617 turbo in 3Rd 4th or 5th grears, can anyone recommend a good clutch upgrade, the clutch diameter  is 228mm at the moment I'm thinking a g wagon or t1 van clutch which is also 228mm might work can anyone confirm or deny if this will work before splash cash on a new clutch?
This post was last modified: 09-17-2016, 07:34 AM by 300sd/5speed.
300sd/5speed
NZScott
HX30W 73/44mm
398
09-17-2016, 04:36 PM #2
Not 100% sure but those clutches/pressure plates are the same to my knowledge.
That's a real bugger about it slipping though, I have a brand new stock 215mm one behind my souped up 617 so I better start looking for a better setup too :/
280GE came with a 240mm clutch however but you'd have to swap/machine the flywheel and if you were going to that length you'd be best off going for a proper performance clutch.
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
300sd/5speed
09-17-2016, 07:37 PM #3
(09-17-2016, 04:36 PM)NZScott Not 100% sure but those clutches/pressure plates are the same to my knowledge.
Yes I think they might actually be the same,  I took the clutch out today it was glazed I think there may have been some oil contamination when the clutch plate was in storage, so now I'm hoping a brand new standard clutch along with a resurfaced flywheel  will do the job properly, fingers crossed.
300sd/5speed
MrHope
10-04-2016, 05:45 AM #4
How about this singlemass flywheel and 240mm clutch.
[Image: 280gekoppling240.jpg]
W124 300D 1985 (daily driver)
MrHope
juggs
10-04-2016, 09:19 AM #5
What is that setup in the photo above?
juggs
300sd/5speed
10-05-2016, 06:29 PM #6
[quote pid='83288' dateline='1475577911']
[/quote]
Is that from a g wagon with m110?
300sd/5speed
[/quote]
NZScott
HX30W 73/44mm
398
10-05-2016, 08:24 PM #7
Yup pretty sure that's the 280GE setup I mentioned, I could do with that actually Tongue
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
MrHope
10-19-2016, 04:36 PM #8
Yes its from a 280ge
MrHope
 6 Guest(s)
 6 Guest(s)
