STD Tuning Engine om617 coolant hoses
om617 coolant hoses
om617 coolant hoses
yota4life
09-17-2016, 03:30 PM #1
So finally got my om617 swap running. Now here's my question the hose by the oil filter I'm assuming is a coolant hose. Can I block that off without issue
yota4life
NZScott
HX30W 73/44mm
398
09-17-2016, 04:10 PM #2
Yes if you don't want the cabin heater.
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
yota4life
09-17-2016, 04:37 PM #3
Ya I removed all the heater stuff. Thanks for the quick reply
yota4life
Bigpanda16
09-19-2016, 08:28 PM #4
I'd think you'd want to loop it so it bypasses the cabin but does flow out of the back of the head. Isn't its function to keep the rearmost cylinders cool?
78 300D, 87 190D, 94 E320, 95 E300D
Bigpanda16
NZScott
HX30W 73/44mm
398
09-19-2016, 09:07 PM #5
Manual climate control at least stops flow through that circuit completely. When doing performance mods, on all 6xx engines it's a good idea to loop it as you say
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
