5 speed 300sd m110 flywheel clutch opitions help!
Hi people I'm new the forum!
My issue is I converted my 79 300sd to A 5 speed manual from a 300d using an m110 280se flywheel the problem is the stock m110 clutch won't hold the torque from the modified om617 turbo in 3Rd 4th or 5th grears, can anyone recommend a good clutch upgrade, the clutch diameter is 228mm at the moment I'm thinking a g wagon or t1 van clutch which is also 228mm might work can anyone confirm or deny if this will work before splash cash on a new clutch?
Not 100% sure but those clutches/pressure plates are the same to my knowledge.
That's a real bugger about it slipping though, I have a brand new stock 215mm one behind my souped up 617 so I better start looking for a better setup too :/
280GE came with a 240mm clutch however but you'd have to swap/machine the flywheel and if you were going to that length you'd be best off going for a proper performance clutch.
(09-17-2016, 04:36 PM)NZScott Not 100% sure but those clutches/pressure plates are the same to my knowledge.
How about this singlemass flywheel and 240mm clutch.
[quote pid='83288' dateline='1475577911']
[/quote]
Is that from a g wagon with m110?
Yup pretty sure that's the 280GE setup I mentioned, I could do with that actually
Yes its from a 280ge
