opinions
opinions
Ok here it is....... I have a om603 going into my 1983 s10 I have mounted it and everything. I want to rebuild it, it ran good before I pulled the motor it has 200k on it, should I do a rebuild? If yes I plan on a new chain and bearings and rings. Am I going over kill for this engine having 200k on it?
Wow thats crazy I am going to be undergoing that project soon, only I may use a 617, not sure yet. Post some pics please so I can see how you went about it. What are you using as a drivetrain? If I were you as far as the motor I would just roll a chain in it for maintenance purposes unless it has low compression or abnormal engine noise I wouldnt do anything else.
(11-29-2009, 10:06 AM)MB TECH Wow thats crazy I am going to be undergoing that project soon, only I may use a 617, not sure yet. Post some pics please so I can see how you went about it. What are you using as a drivetrain? If I were you as far as the motor I would just roll a chain in it for maintenance purposes unless it has low compression or abnormal engine noise I wouldnt do anything else.
the pics did not come through, but I will try another computer later on. Not sure what your using for a radiator but I know summitracing was where I bought one for my wagon ( a universal all aluminum for about $250) It was a good buy, plenty of cooling capability and no more plastic tanks to worry about. Ya I am a tech at a mb dealer.
(11-30-2009, 08:34 AM)MB TECH .....I know summitracing was where I bought one for my wagon ( a universal all aluminum for about $250) It was a good buy, plenty of cooling capability and no more plastic tanks to worry about. Ya I am a tech at a mb dealer.
here is the link http://www.summitracing.com/parts/SUM-381324/ it took a little modification, I also do not use the factory engine oil cooler, I mounted an aftermarket one underneath near my intercooler. For the radiator hoses I just went to an auto part store and bought the longest hose with the closest bends that I needed. I will try to take some pics of it tonight and post them.
Well ordered parts for the engine today I got a bunch of gaskts to reseal some leaks and the I decided to roll a new chain into the motor and replacing all glow plugs, ths includes a turbo rebuild kit as well. I purchased all oem parts to be on the safe side luck me I work at a benz dealer and get a great deal on parts I am very fortunate. I will post more pics soon.
