STD Tuning Engine OM601. take out injector after 300-400Kkm
Jonas94
12-10-2016, 03:04 PM #1
Yes, today i have changed out my hydraulic valve tappets on my 190D OM601.
got some new nozzles yesterday as well, and was planning to replace them.
Lot the engine get hot and stoppet it, took of the pipes, and got a 27mm wrench witch was maked for this aplication.
But the injector sat as h*ll
Used a long arm as well, and the hole engine turned over.. and the car started to turn abit to..
Soo, how do u solve this kind of problem? ican see some rust on the injector also.
Planning to travel to the workshop and have som rust looser/penetrating oil on the top where the injector is attached.
But how do u people loosen them?Smile
75nm to tourqe them to when instaling, right?
Jonas94
12-11-2016, 05:09 AM #2
Use a pneumatic hammer wrench or what the hell that thing is called in inglish, the air tool that is used in tyre shops. The hammering efect will release better than anything u can ever imagine.
Jonas94
12-11-2016, 05:24 AM #3
One of thees you ment?
[Image: images?q=tbn:ANd9GcRsMR3C5dKE5rvfZCvdJT3...kFyC8WOUHu]
Jonas94
Jonas94
12-11-2016, 11:02 AM #4
Yes, then after a lot of strugle i got them up.
Adjusted them to 135-145Bar range (that what i could find on OM602/3, soo i thought it was the same to OM601. The last injector i adjusted i read 115Bar on the housing. Fuck, so tomorrow i have to take them up and adjust them downSad
BTW i changed the nozzlesSmile
Jonas94
Dieseeelstar
12-11-2016, 01:50 PM #5
Naturally aspirated engines have 115bar and turbo engines have 135bar from the factory
Dieseeelstar
Jonas94
12-11-2016, 03:32 PM #6
What will happen when its higher pressure?
More diesel when it opens? the engine will get to much diesel..?
Or will it close earlyes because its higher open pressure, so the engine will get to little diesel?
Jonas94
seanyt
is300d He351ve
279
12-11-2016, 03:40 PM #7
higher pressure slightly less flow.
But usually people upgrade injectors to higher pressure.
Like turbo guys going from 135-150bar i know dieselmeken recommends it for his pumps.
and im yet to do it when i get time to remove my injectors. so i cant comment on the benefits.
seanyt
erx
w202 om606
323
12-11-2016, 04:42 PM #9
https://www.youtube.com/watch?v=SKCJZ69zVqY
In this video there's definitely something more wrong than only pop pressures. It sounds like one injector is making horrible knock.
erx
Jonas94
12-11-2016, 04:56 PM #10
Can it be cause by to high opening pressure?
Jonas94
12-11-2016, 05:27 PM #11
google, impact torque wrench , is not that tool , the tool above is for masons Wink
IDI injectors , don´t really need to have the nozzle replaced, unless they pee too much and one can´t have them spraying good and sealing. good quality nozzles (bosch, bosio, etc) are expensive, and don´t change much (performance).... pop pressure has a lot to do with the sealing and the noise, higher the pop pressure louder the nailing, in a performance built pump having the pop press to higher value helps in the quick response under boost...
But if u want your 601 to rock , i have a special 6mil pump for u... anyway u have to turbo it...
Jonas94
12-12-2016, 03:43 PM #12
After work today i took out the injectors, and adjusted the pressure from 140Bar ish, to 115Bar.
A lot less smoke, and som less shaking from the engine. But more the engine was running, the less it was shaking. So gues it have somethink with the "drive-in" of the nozzles..
I dont think i want to turbocharge it.. Then i rather buy a w124TDT Smile want to change out my gasoline S210 Smile
Jonas94
seanyt
is300d He351ve
279
12-12-2016, 03:46 PM #13
I believe when you raise the pop pressure it alters the injection timing.
Leaving it at 140bar but adjusting the timing may have resolved the shaking and smoke.
seanyt
Jonas94
12-12-2016, 04:23 PM #14
Is there any timingmarks you can see on the pump? like the camshaft/crankchaft marks?
Higher poptiming, is later injection because the pump need some more time to build up that pressure.. so if i could have had it at 140Bar, i had need a earlyes injection delivery.?
Jonas94
 10 Guest(s)
 10 Guest(s)
