Turbo recommendations for C250TD Automatic
I have a 1998 Mercedes C250TD Automatic and I am looking for and extra 100bhp or so. Although I would like more, I believe other parts need to be customised to support the power.
Could I get some advice on what turbo would suit my requirements or if I should actually get my turbo rebuilt and hybridised?
Thanks
HUM, turbo will not give u that extra 100hp,
U need a better injection pump, and then with a gt 23V u can achieve the nr and drive as much as u want with that setup.
besides that , since your car has a ECU to control a Electromechanichal pump , some sort of remapping is always needed, and is not easy in your car.
for the pump i can help u with, the ECU i´m fighting to have one ready, by forum members like stary novy claim to have that thing sorted out.
as the end of conversation , first u should consider the IP, only after the rest.
regards , and welcome
As said, give that at least 6mm elements from 300TD EDC pump, stock 5.5 are way too small for any serious power gains and are even too small to max out stock turbo with pressure operated WG.
(12-10-2016, 03:13 AM)Antonio bigger downpipe or can it stay oem?
