STD Tuning Engine Oil Cooler Pipes
Oil Cooler Pipes
Oil Cooler Pipes
matfield
12-16-2016, 10:37 AM #1
I'm having a battle with my oil cooler pipes on the OM606. I brought it to my local hydraulic specialist who against my better judgement cut off the original mercedes pipes (that weren't leaking), and crimped on ¾" hydraulic hose, that now leaks out of the bottom hose constantly.
I've been back 4 times to try and have the problem solved and there seems to be no solution other than his suggestion that I bring in another set of mercedes pipes and we adapt to suit with new fittings (my face was not pleased with this solution!)
I suggested using ⅝" hose, but was told that it won't fit over the 606 engine fittings.
At start up I'm getting around 70psi of pressure that drops gradually to around 15psi when warm, so I'm not sure if hose clips will work.
I'm wondering what other people have done at the engine end, or if I'm just going to have to find another set of pipes to have adapted.
Thanks
Mat
matfield
Thanks
Mat
12-16-2016, 11:50 AM #2
Good quality clamps hold well. Oil pump is rated at 8 bar (relief valve) use 20 bar hyd / fuel hose .
zeeman
12-16-2016, 12:16 PM #3
(12-16-2016, 10:37 AM)matfield I'm having a battle with my oil cooler pipes on the OM606. I brought it to my local hydraulic specialist who against my better judgement cut off the original mercedes pipes (that weren't leaking), and crimped on ¾" hydraulic hose, that now leaks out of the bottom hose constantly.
Thanks
Mat
I cut the end off and silver solder a male  - 12 A/N fitting on. then you can crimp what ever -12 A/N female fitting you want to use with the 3/4" inch hose. I should have a pic in the engine section.
This post was last modified: 12-16-2016, 12:19 PM by zeeman.
zeeman
Thanks
Mat
matfield
12-16-2016, 02:29 PM #4
Is 12 A/N equivalent to ¾"? I've tried to get my head around the A/N stuff and its not too logical.
matfield
baldur
Fast
509
12-16-2016, 07:12 PM #5
Yes, 12 AN is 3/4". Those AN sizes are specified in sixteenths of an inch.
Baldur Gislason
baldur
Baldur Gislason
matfield
12-18-2016, 03:28 AM #6
Thanks for the help!
Barrote: I'll try removing the crimp that's on the hydraulic hose and put a couple of hose clamps on each fitting.
Zeeman, do you have a link that post? I'm assuming the engine side fittings are aluminium so could also be brazed with a TIG welder? Hopefully the hose clamps will work, but failing that I'll find some A/N fittings.
Mat
matfield
Mat
50harleyrider
GTA2359VK
397
12-18-2016, 10:53 AM #7
Look at Zeeman's post 10 of this thread. http://www.superturbodiesel.com/std/show...p?tid=7500.
I put an aftermarket Derale oil cooler on mine and am planning on barbed fittings with double hose clamps. Will see .
This post was last modified: 12-18-2016, 10:54 AM by 50harleyrider.
50harleyrider
matfield
12-18-2016, 11:53 AM #8
That makes sense now... I don't even need to get A/N fittings, I can just get some male BSP fittings (easily found here, A/N would be more expensive and harder to find) and braze/silver solder them on.
I think thats the way to go. I'll speak to the new hydraulics guy tomorrow and see what he has.
Thanks again lads... much appreciated!!
Mat
matfield
Mat
zeeman
12-18-2016, 10:21 PM #9
(12-18-2016, 10:53 AM)50harleyrider Look at Zeeman's post 10 of this thread. http://www.superturbodiesel.com/std/show...p?tid=7500.
I have never been a fan of clamps on a oil hose, they always leak at some point. Loosing a engine because of a oil hose coming loose is not worth saving a few dollars, do it right the first time. But if one must use them instead of crimping, use Norma clamps from Germany so they don't tear the hose when you tighten them.
zeeman
zeeman
12-18-2016, 10:24 PM #10
(12-18-2016, 03:28 AM)matfield Thanks for the help!
Mat
The engine side fittings are steel so they can be silver soldered.
zeeman
Mat
50harleyrider
GTA2359VK
397
12-19-2016, 06:19 AM #11
Whenever I use worm gear clamps I double wrap the hose with friction tape to avoids tearing into it. T-bolt clamps are the best and I always use them if possible. Crimping is the best of course.
50harleyrider
50harleyrider
GTA2359VK
397
12-19-2016, 06:20 AM #12
Whenever I use worm gear clamps I double wrap the hose with friction tape to avoids tearing into it. T-bolt clamps are the best and I always use them if possible. Crimping is the best of course but we're looking at <100 psi here.
50harleyrider
 7 Guest(s)
 7 Guest(s)
