strange sound in om603 turbo
I was out driving yesterday, with a s124 om603 turbo. suddenly there came a knock knock sound. idling there is no noise, but if I revs it the sound comes back.
I think it could sound like metal against metal, so no pretty noise ..
enough oil pressure and oil in the engine..
Any ideas on what it might be?
hmm... I have not been checked, but I have been told that the piston rings are broken..This engine has lived a tough life. before I bought the car in November, I was told that it had clogged radiator which led to 120 degrees cellsius. I also have a problem with that I must glow engine regardless of temperature.
Could this be related to the sound?
barrote - if rod bearings, the sound could come and go?
failed bearings , sooner or later will tell u the truth , there´s nothing to do .... sure is something else, if the rings break the engine will loose all its ability to compress air, would be very dificult to start and they would stick in the Groove , and nothing good would come out....
used it untill colapse then ,, repair if possible.
