STD Tuning Engine 4 bar boost sensor in OM612, 270 cdi
tgg416
01-06-2017, 01:40 PM #1
Hello, can someone explain whats the gain in changing the original 3 bar boost sensor to the 4 bar boost sensor ?
Trick the ecu to boost more ?
Tanx for help.
Gwagen 460, om606.962. 722.6 Ole Fejer controller++
Gwagen 463, shitty 603,,,,at the moment,,,
Gwagen 463, 270cdi
tgg416
Tanx for help.
Gwagen 463, 270cdi
hents99
01-06-2017, 01:44 PM #2
ECU can see 1 bar of more boost pressure.
Can`t tell you if it`s reasonable to heat up the air with extra pressure.
400kPa absolute pressure?
www.elbe.ee - MB performance parts.
hents99
seanyt
is300d He351ve
279
01-06-2017, 02:48 PM #3
The gain is your ecu will see upto 3bar boost.
It is only benefitial if your turbo and injector and pump will flow enough for 3bar boost.
Also without rescaling a new map sensor. The car will run more boost but use less fuel. So no benefit other than cleaner running as it will run leaner.
This was a mod people did on om605/6 map sensors with a resistor.
ECU would see less boost so raise boost level BUT it also injects less fuel for the amount of boost. Then they fit evry mod to try raise fuelling, this works okay but upto a point only.
On CDI cars you can trick fuel temp sensor, rail pressure sensor and intake air temp sensor to try raise boost.
But ultimately a remap is the best bet for CDI
seanyt
seanyt
is300d He351ve
279
01-06-2017, 02:59 PM #4
Also a side note, the only exception is a map sensor that places atmospheric pressure at a higher voltage point like some higher pressure map sensors and the car will think it has some boost and will fuel accordingly.
In this case it will have more off-boost fuelling but less onboost fuelling.
seanyt
tgg416
01-06-2017, 04:26 PM #5
Ok so if I change injectors and also do a mapping, then I dont need a 4 bar boost sensor if Im not going to boost more than 2 bar,,
Gwagen 463, 270cdi
tgg416
Gwagen 463, 270cdi
seanyt
is300d He351ve
279
01-06-2017, 04:53 PM #6
depending on your goal just a remap may do.
You haven't specified a power output or swapped turbo or hybrid turbo.
There are plenty of re-mappers who can do this for you.
Amg injectors will give you more power alone without a remap but are an expensive and possibly not necessary way of getting power.
seanyt
baldur
Fast
509
01-06-2017, 05:45 PM #7
Also, if you are not depending on the ECU to control the boost, it's okay to run more boost than the MAP sensor can read.
Baldur Gislason
baldur
Baldur Gislason
MartinB
OM605 Power
154
01-06-2017, 08:48 PM #8
AMG injectors are nonsense without remap.
MartinB
MartinB
OM605 Power
154
01-06-2017, 08:51 PM #9
Original MAP is up to 1.5bar boost.
MartinB
starynovy
01-07-2017, 04:02 AM #10
Baldur> No, you cant. ECU has requested boost map and if the certain value is not obtained in certain time with certain precision then limp home mode. With EDC15VM this is tolerance of 40kPa for overshoot and 4 seconds.
starynovy
baldur
Fast
509
01-07-2017, 06:54 AM #11
(01-07-2017, 04:02 AM)starynovy Baldur> No, you cant. ECU has requested boost map and if the certain value is not obtained in certain time with certain precision then limp home mode. With EDC15VM this is tolerance of 40kPa for overshoot and 4 seconds.
Yeah obviously this will only work on a modified ECU...
Baldur Gislason
baldur
Baldur Gislason
tgg416
01-07-2017, 10:17 AM #12
Amg injectors is ordered, and then I will also remap.
So thats why I wonder if I should change to 4 bar sensor togheter with this work and why ?
Im not going extreme, safe boost on this engine i feel would be 1,8-2,0 bar.
Dont think I going to change turbo since so low boost.
Probably another intercooler.
Maybe another oil pump from 320cdi
This is a Gwagen with 156 hp, I will be happy with 250-280 hp
Thank you again for sharing thougts
Gwagen 463, 270cdi
tgg416
Gwagen 463, 270cdi
seanyt
is300d He351ve
279
01-07-2017, 12:43 PM #13
Dont think of the boost as the limiting factor for the turbo.
A larger billet wheel, will still spool the same also handle the same boost BUT flow more so is more efficient at making power in higher revs and is ultimately your best benefit matching larger injectors and ecu remap.
The stock turbo will limit you goals but it hasnt enough flow/ head room for 100-120hp if this is your goal.
stock map sensor is fine for these upgrades though.
Can you even swap in a 320cdi turbo. i dont know what size is fitted to your car off the top of my head.
seanyt
starynovy
01-10-2017, 03:35 AM #14
There is GT22V on 270CDI and 320 uses GT23. If you wont upgrade high pressure pump you can leave that GT22 there, but forget 2Bar, it will fall apart. Around 1.6Bar is pretty safe.
starynovy
 11 Guest(s)
 11 Guest(s)
