STD Tuning Engine Oil temperatures
Oil temperatures
Oil temperatures
Mallinman
01-17-2017, 04:30 PM #1
Just wondering what sort of oil temperatures people are getting with regular daily driving and with what oil.
  I've had a good search of the forum but didn't come up with much. I'm just curios and wanting to compare. It would be interesting to see what different people are using in different parts of the world with different climates
Mitsubishi L200 manual om605
7.5mm Bosch 044 fed pump
Borgwarner S200
Mallinman
Borgwarner S200
R-3350
Dreaming of compounds
182
01-17-2017, 07:51 PM #2
i have a sensor that replaces the drain plug on my 617 and i regularly see ~120-160*F at cruise. when climbing a grade or at high speed it gets up to around 200-220*F. im working on installing it in the main oil duct in the block to read actual temps as the sump cools quickly and is not a true reading but those are some data points for you. mind you the 617 has a thermostatically controlled air to oil cooler i don't know if the later 60X engines use the same set up or an air to water cooler in the cooling circuit.
R-3350
maxypriest
01-18-2017, 08:02 AM #3
These engines can get very hot. Oil water and EGT; My advise is fit a large oil cooler!
I don’t know what my temps are however I have a medium sized (space restricted) oil cooler plumbed into the oil filter tower (that is thermostatically controlled).
I use Mobil1 Turbodiesel as its stable at high temps and I change it every 2k.
maxypriest
Sultzi
01-21-2017, 03:58 AM #4
I have pretty much same temperatures in 606compound measured from the same place than R-3350's 617 has, oil drain plug.
Stays in 120-160f at normal driving. With hard driving or slow city driving it goes near 200f. I have original 603turbo oil cooler and original thermostat controlling it.
Sultzi
Mallinman
01-21-2017, 04:13 AM #5
I'm getting about 100'c on normal driving and about 110'c on heavy driving using 10w40 oil. That's using the standard oil cooler on the side of the oil filter on the 605. It never goes over those temps but it does seem a little high compared to everyone else's. I might have to put on an external oil cooler.
Borgwarner S200
Mallinman
Borgwarner S200
Petar
7.5mm M pump
459
01-21-2017, 09:23 AM #6
I think that's actually good, the oil temp should exceed 100 °C regularaly so that moisture is boiled off from it. That's what i've heard, i'm not an engineer.
Petar
Sultzi
01-21-2017, 11:06 AM #7
That's true, most of the oils are designed to work best around 90-100c of temp. Too cold is worse than 90c oil.
Sultzi
Mallinman
01-21-2017, 12:59 PM #8
That's ok then. I was getting a bit worried that they were 2 high and would cause failure. The coolant temp stays at 80 all the time. Not had it in summer yet tho. That's with the coolant mod pipe and using the big radiator thats in the l200 with twin 16" fans. Electric thermostat is set at 70c for the fans. I'm paranoid about overheating.
Borgwarner S200
Mallinman
Borgwarner S200
05-17-2017, 04:29 AM #9
Agreed. I got a big one also, that's what she said.
It's going to be tight, that's also what she said..
[Image: oil%20cooler%201.jpg]
[Image: oil%20cooler%203.jpg]
This post was last modified: 05-17-2017, 04:30 AM by Hario'.
Mallinman
05-17-2017, 08:52 AM #10
It will fit. Everything fits with patience. And a massive hammer.
Borgwarner S200
Mallinman
Borgwarner S200
Evenglass
05-18-2017, 09:55 AM #11
(05-17-2017, 04:29 AM)Hario\ Agreed. I got a big one also, that's what she said.
What is this cooler from?
Evenglass
05-21-2017, 01:31 PM #12
(05-18-2017, 09:55 AM)Evenglass
Land Rover P38 oil cooler
Mallinman
05-22-2017, 02:38 PM #13
If it can keep a p38 cool then I'm sure it will work great on car that's not designed to overheat.
Borgwarner S200
Mallinman
Borgwarner S200
starynovy
05-23-2017, 06:37 AM #14
Lol ?
starynovy
Lol ?
