STD Tuning Drivetrain 722.6/Nag1 valve body and transmission brake.
whipplem104
01-18-2017, 03:24 PM #1
Just wanted to let everyone here know. I currently offer modified valve bodies for high performance applications. I will work with your core or a new core. The modifications are 450.00 on a used valve body. I can get remanufactured parts for an additional 600.00 with no core return. So I can supply a unit for 1050.00. No solenoids or conductor plate. Those parts will have to be swapped.
On the transmission brake for drag racing applications this is a 3000.00 setup. This includes a new valvebody, conductor plate, solenoids, and modifications to the valve body for the transmission brake. Also included is the modified valve body mentioned above. Also a new pan and filter. The pan is a deep pan that is several inches deeper.
You will need a trans brake controller to use this properly and safely. It will not lock in 3rd or above.
whipplem104
Sultzi
01-19-2017, 04:00 PM #2
Very nice! Been watching this on facebook.
What kind of difference is noticable with that modified valve body (without transbrake)?
Sultzi
whipplem104
01-19-2017, 08:37 PM #3
Available pressure in the upper gears is near double. So 2-3=3-4=4=5 are all near double available pressure for the shift. Also the main pressure from 2nd up is near 50% increase.
It makes a huge difference. We have taken a stock transmission in a TT jeep srt8 to a 9.6- 1,4 mile.
whipplem104
Sultzi
01-21-2017, 04:05 AM #4
Ok, that sounds pretty nice. Will that also make that 3-4 flare tuning more difficult? That modified valvebody works with std solenoids?
Sultzi
whipplem104
01-21-2017, 05:17 PM #5
It does not effect the 3-4 shift. I do still open up the port for k3 when doing them. I really do not have that problem with the newer generation tcm-2800 due to the way we are controlling pressures now.
whipplem104
