Need information for 500 HP Setup OM606
Hi Guys!
This is my first post here.
I´m from Germany...the hole Superturbodiesel "Thing" is completly unknown here so I have bit issues with my Project.
My Project Car is a `91 W201 with a 1.8 M102 in the Moment.
I want to use it for Racetrack only and my wish were 500HP and 800+Nm
The Parts I already have:
-w210 with a 177HP Om606 (224000km on ODO)
-BMW ZF5 Gearbox
-Gearbox Adapter Plate from DPUK
-Clutch Kit and Singlemass Flywheel from DPUK
-8mm Mechanical Injectorpump with 190cc from DPUK/Meken
-Holset Super HX40/16 without Wastegate
Things I know:
-I must upgrade the Injectors to 150 Bar Popping Pressure
-I Need Minimum 3,5" Exhaust Pipe
Things I don`t Know (that´s the Point where you Guys come in):
-Are there any modifications needed on the Oilpump?
-Will I Need a W124 OM603 Oilpan and Pump to fit in W201?
-what Components and Configuration for the Fuel System? (Feeding Pump, Fuel line Diameter, Pressure Regulator, Catch Tank used?,...)
-Do I Need other Nozzles than the Stock?
-Witch Oilfilterhousing needed for external front Oilcooler using
-Diameter for Hoses to Intercooler and to Intake Manifold
-Modifikation for Intake Manifold?
I hope you Guys (understand my English and...) can Help me to reach the 500HP and bringing the Blacksmokers to the Homecountry
(10-03-2016, 01:40 PM)Blackflag Things I don`t Know (that´s the Point where you Guys come in):
If u guys don´t mind lets me buz in the topic....
I think theres´s a lot behind a over 80thi´s HP cylinder engine, that most probably don´t consider.... wich can be hard to tackle, in the race track its difficult to wait for boost to come in order to avoid the "others exhaust" fumes....
1-engine cooling, probably u will have to improve your coolant radiator to another 50% cooling capacity, and mod the cooling circuit to reach the rear cylinders, nothing special, there are many mods for that available in this forum.
2-engine cooling, in diesels the piston crown cooling is so vital as it is in any other engine , the thing is that the forces involved in this HP´s tend to generate a lot of heat , and the oil will boil so fast that it can lead to piston collapse , so the oil radiator should be of considerable size, lets say twice the size the original w460 300GD.
3-engine fueling, if u have the 8mil dieselmeken(which i know well) element pump, its good for those HP´s u want. the 7.5mil may be conservatively small, (i´m not saying its impossible) either way the pump need´s a dedicated fuel supply system , able to provide 200lts/h at 1.5 bar pressure in the main gallery, (post filter) in order to pump at max output at 6k.
4-the injection system, is not only composed by the IP, there´s a lot more than set the injectors at 150BAR pop press, but its a IDI system , the pre-cup system it uses need´s a small mod, usually bigger holes help , something from 2.5mm to 3mm.
5-if i have been aware those members shooting at those HP´s are running some kind of overlap and lift mod cams, which can be achieved with a N/A exaust cams.(intake is usually the same part#) and just cause we are talking of cam´s , why not to talk about valve springs, usually people install harder springs, one drop in spring has a part number A611.02 XX XX , and another one which can be made to drop in , is A111.02 XXX .
6- the most important, Turbomachinery able to pump 3.5 bar boost from 2.5k until 5.5k , with a EGP/boost ratio of at least .80 maximum during the peak power. 3k to 5k. well i vote for sequential, but unfortuntly i can only say that your HX40 is small for LP turbo and too big for HP turbo. and of course a big enough aftercooler, intercooler what ever u want to call it.
and a litle more this and thats... if u have specific questions pm.
regards
What should the timing be? 12 degrees as opposed to the stock 15 degrees with the mentioned setup?
