STD Tuning Engine No fuel return line?!
Fishman
03-12-2017, 02:36 AM #1
Is it possible to run te mech pump without a return line? Was thinking of putting a low pressure hi flow fuelpump in the fueltank, feeding de ip-pump. Then connect the return line with a T between te electric en mech pump. Will this work?
Fishman
03-12-2017, 03:26 AM #2
It will. Question is how are u going to bleed the main gallery?
Instead of doing that use a 1.5bar check valve at pump return line. Actually the return exit is just for this purpose to bleed the system. And some excess pressure when engine is unthr .
U must by pass the mech lift pump at all cost. It reduces flow a lot.
Nevertheless u might find a good solution irespective of what i'm saying
Regards
Regards
Fishman
03-12-2017, 03:28 AM #3
Thanks. I will use the 1.5 bar check valve.
Fishman
starynovy
03-12-2017, 03:54 AM #4
Would not do that.. spent fuel which leaks trough spill ports is hot as fuck. So if you drive on low power there is lot of it and temperature builds up quite fast. Same goes for VE pumps, there is tiny 0,15mm orifice with spring loaded plunger for even more recirculation at high revs.
starynovy
Fishman
03-12-2017, 05:58 AM #5
My problem is that my Jaguar has 2 fueltanks, wich can be switched with a switch. So when i use tank 2 and the return line is in tank 1, it can overflow.
This post was last modified: 03-12-2017, 05:59 AM by Fishman.
Fishman
matfield
03-12-2017, 12:52 PM #6
Could you put an overflow between the two tanks, or join the two tanks and save the need for two in tank fuel pumps?
matfield
Fishman
03-12-2017, 01:20 PM #7
Think that is the best option.
Fishman
AlanMcR
mind - blown
400
03-13-2017, 04:35 PM #8
The standard setup is to switch the return lines when switching the feed lines. This way one can run veggie in one and diesel in the other and not get them mixed up (much).
AlanMcR
