102mm vs 115mm head bolts
I just got my head in a good machine shop so now it's time to hit pelicanarts and order everything to tie this up. What is the difference between the short and long size head bolts? I would assume that 102mm is for regular set up and the longer 115mm is to accomodate the thicker head gasket AKA repair head gasket? thank you very much for all the input it has really been helping my journey so far.
Difference between gaskets is something like 0.2mm total so no.
(03-29-2017, 02:05 AM)barrote U have 30 bolts plus 2 m8 . Those 30 6 of them are 115 or what ever they state. Why dont u use the old ones? This is a MB everithing is reusable. Have rhe tolelance checked and use them or not.
Well then someone fucked those bolts by not obeying tightening sequence. We measured bolts from 606turbo with 1 milion km on it and they were like new. Reused twice, still holds and measures the same.
The principle behind strech bolts is the elasticity principle of stell.
Wich is afected by heating cycles..... and after some 50.000 heating cycles, more or less one milion km,(i´m guessing) the must be able to still maintain its elasticity principle. The MB repair manual states 2 kinds of bolts, common bolt and strech type, measure them to avoid going too deep in well, and tight against the bottom instead of the walls (threads). (or in some cases of extreme distortion/strech they may no longuer be in condition to be used again)
But anyway is a myth, and myths are what they are
(04-02-2017, 04:37 AM)barrote The principle behind strech bolts is the elasticity principle of stell.
Regarding MB´s I only know one thing, after the 60´s untill the apearence of euro6 rules the "philisophy" was repairable production, with spares on condition, even gaskets and O rings are of such nature that they were made to use on condition.
If one read carefully, the repair manual states very often tolerances, the idea is for the user to choose wiselly weather to use new or used.
anyway there are always myth´s so as rings and so on...
Here are the cylinder head bolt pages from the MB manual (attached PDF). These pages assume that you are using the factory multi-layer steel headgasket.
List of bolts, Tightening pattern, Length limits, How to measure.
(04-03-2017, 01:49 PM)barrote I could read "if bolt excedd X measure use new bolts".
Wich cames to mind the Myth thing again
But i don't have any dought...
(04-03-2017, 09:17 PM)atypicalguy(04-03-2017, 01:49 PM)barrote I could read "if bolt excedd X measure use new bolts".
I am not sure I understand you. The manual says exactly that: if the bolt is longer than 117mm, use a new one.
You can tell the bolts are designed to stretch because the manual specifies an angle of rotation for the final two stages. You torque it, then rotate 90 degrees to stretch a bit, then wait for it to stretch 10 min, then rotate it another 90 degrees to put the final stretch on it.
(04-04-2017, 05:59 AM)Evgeniy1987Thanks but I think you are agreeing with what I wrote, not disagreeing.(04-03-2017, 09:17 PM)atypicalguy(04-03-2017, 01:49 PM)barrote I could read "if bolt excedd X measure use new bolts".
May I disagree on that one, please?
The fact that they prescribe a certain angle is because an angle is by definition more precise than a torque, because the total torque is an add up of bolt stretch and frictions: friction in threads and friction at bolt head contact area.
A certain stretch force ( = force that holds the head against the block) is reached by a certain stretch of the bolt.
An angle is a direct conversible measure for stretch, while torque is not...
Then there is something like "necessity of precision" or something: they could also say like "torque to 130 Nm".. but because of earlies described reasons, this torque may cause to few bolt stretch, which then causes to few force. Even worse: different per bolt..
I therefore disagree, that the statement "rotate 90 degrees" automatically implies stretch 1-time-use bolts. It can be done for precision reasons.
(04-04-2017, 10:29 AM)atypicalguy(04-04-2017, 05:59 AM)Evgeniy1987Thanks but I think you are agreeing with what I wrote, not disagreeing.(04-03-2017, 09:17 PM)atypicalguy I am not sure I understand you. The manual says exactly that: if the bolt is longer than 117mm, use a new one.
I only said the angle means that the bolt stretches. I did not say it was a single use bolt. They may be reused if they are within the specification in the manual page supplied above.
I am wrapping up my head gasket aka glow plug gone wrong ordeal. So on Om606 we have 26 total serrated 10mm head bolts. 20 are short 102mm and 6 are long 115mm. Oiled bolts with clean threads in block are important as well as clean prepped surfaces. I took apart 2 606 heads this month, my turbo 606 and an na 606. I purchased new Victor reinz head bolts just because everyone says safe then sorry... but i did micrometer and also visually compare these to the original MB bolts for curiosity sake and they were dam close to each other and totally all in spec no where near 2mm stretch. These bolts are incredibly durable even the serrated triple square head resists stripping/rounding. The last 90 degree turns had me sweating taking my time because boy do they get TIGHT! Have injectors and lines to attach tomorrow as well as buy fluids i will crank this sucker over. My 2 cents is that i saved all my extra headbolts and on my next future head gasket job i will reuse these. I believe these bolts do stretch under the tension against the head but upon removal they retain their elasticity of sorts and go back very close to their natural length...
