Edc injector pump issues
I was wondering if there was anyone with enough knowledge here to identify the cause of my problem.
I have a w210 with a 606 and it doesn't want to run. It worked one day and not the next day. I've eliminated everything bar the shutoff valve and injector pump. I have an electric pump forcing fuel into the filter and the SOV but there doesn't seem to be much fuel coming out of the pump.
I have changed the filter for a new one. The o ring behind he SOV has not been changed yet but i don't see how it could cause this issue. The most likely situation is that the IP is fucked but I dont have much experience with them so I can't say for sure.
Here's a vid:
(04-24-2017, 11:34 AM)hooblah I was wondering if there was anyone with enough knowledge here to identify the cause of my problem.
Here's a vid:
Here's a vid:
The immo is fine. The SOV clicks when you turn the key, and then clicks again after 30 secs.
The SOV or delivery valves aren't leaking from what I can tell. I will be replacing the SOV seal tomorrow. I will replace the DV seals once I get it running. I can't see that being the reason why there's nothing coming out.
