STD Tuning Engine Free warning buzzer/alarm
12-04-2009, 05:21 PM #1
Sending positive voltage to pin 9 of the stock seatbelt warning buzzer will activate it as long as the voltage is applied. Sending power to the blue wire of the seatbelt switch harness will do the same.
It would work well for manual glowplugs, high water temperature, low oil pressure, overboost, etc.
Nick
Big diesel's need lovin' too
38
12-05-2009, 12:26 PM #2
Man good idea. There's been a huge buzz recently about low oil pressure alarms, I think this would simplify any warning system a lot..
I've had that seat belt wire under the drivers seat unplugged for a while now..
Nick
kamel
Naturally-aspirated SUCKS
176
12-06-2009, 02:29 AM #3
Hmmmm, ripped mine out first day I got the car...
kamel
12-06-2009, 03:04 AM #4
It wouldn't difficult to make. All it consists of is a relay that breaks power to its own coil when energized and a few transistors and resistors to control the 4-8 seconds timing of the seatbelt buzzer/light.
This post was last modified: 12-06-2009, 03:07 AM by ForcedInduction.
