STD Tuning Engine om605 boost
om605 boost
om605 boost
Antonio
07-25-2017, 06:02 AM #1
hi, om605 wont go past 0.5 bar... turbo and vacuum actuator like new from c250td OEM
... i have switched it from vacuum operated to old pressure operated actuator... but that actuator works pretty rough comparing to vacuum actuator that travels pretty easy. is that mybe a problem??
[Image: p5pb14977334.jpg]
Antonio
STDGer
07-28-2017, 02:01 AM #2
Hey mate, did u already block the wastegate by a wire to test if its a turbo problem?
Im at the moment on nearly the same problem, but i cant get above 1.5 bar from my t04e. I think my problem is the gasoline aftermarket sport exhaust.
What about ur exhaustpipe?
STDGer
Antonio
07-28-2017, 08:13 AM #3
(07-28-2017, 02:01 AM)STDGer Hey mate, did u already block the wastegate by a wire to test if its a turbo problem?
so i havent blocked it, but shure i will do it this evening... im getting just 0.5-6 bar. Can i block it and drive like that or not?
i have 65cc fuel from 6mm elements with 76mm exhaust. have you found any aftermarket pressure operated actuator on ebay or somewhere else?
cheers!
This post was last modified: 07-28-2017, 08:14 AM by Antonio.
Antonio
cheers!
STDGer
07-28-2017, 09:58 AM #4
Test it. Will Not rest for long with a wire.
Buy a nice Upgrade. Maybe a gt2871 oder t04e like me.
Theyre pressure controlled
ex 04. 1997 w202 om605 sedan ,Dieselmeken 7.5mm, 3" exhaust, he351w, 716.657 ca 350+ hp
actual 08. 1997 w202 om605 station wagon, oem edc pump, modded exhaust manifold, t04e turbo, oem pipe 1 silencer wannabe as much as possible
STDGer
