STD Tuning Engine Final version Om606 EGR defeat?
Photomonkey
08-17-2017, 08:37 AM #1
Hi guys,
I've been slowly modding my E300 W210 and it's time to tackle the EGR defeat.
Digging through old posts it's hard to see what the final result was for the resistors in the resistor/diode solution.  Most places seem to reference the same relevant wires, the same diode, and at least one resisitor.  Some threads however have a higher resistance on the defeat circuit.
Can anyone clarify which version seems to be happiest?
Thanks in advance for the knowledge and help.
1999 E300 TD
Photomonkey
Hi guys,
1999 E300 TD
08-17-2017, 01:35 PM #2
Egr?
Where u live u can't find aluminum sheet?
Just phisically block the thing. ?
Egr?
pryantcc
08-18-2017, 08:03 AM #3
(08-17-2017, 01:35 PM)barrote Just phisically block the thing. ?
Don't you still have to fool the computer into thinking that it has been opened with the resister + diode combination?
pryantcc
baldur
Fast
509
08-18-2017, 11:04 AM #4
(08-18-2017, 08:03 AM)pryantcc
Not if you leave the valve in place and connected. The resistor trick is to trick the computer into thinking the valve is still in place if it's been removed altogether.
Baldur Gislason
baldur
Baldur Gislason
08-18-2017, 12:00 PM #5
I got limp when I did that, apparently it compares against maf reading, anticipating reduced maf when egr is open.
seant chipped ecu? get more power then also..
Mr.Emo
Nissan Patrol -> 606 conversion.
69
08-18-2017, 03:08 PM #6
Mine is blocked without resistor, havn't triggered limp yet.
Mr.Emo
MartinB
OM605 Power
154
08-20-2017, 12:42 PM #7
Because you have not MAF.
MartinB
Mr.Emo
69
08-20-2017, 11:00 PM #8
I've got a 98 with maf.
Mr.Emo
AlanMcR
mind - blown
400
08-25-2017, 04:25 PM #9
(08-20-2017, 11:00 PM)Mr.Emo I've got a 98 with maf.
Have you had the ECU tuned? Often the EGR function is deleted in the process.
AlanMcR
Mr.Emo
69
08-28-2017, 01:10 AM #10
No idea tbh. Hasn't bothered me yet. Anyone know of a cheap solution to do diagnosis on the w210?
Mr.Emo
oleg213
08-28-2017, 03:04 AM #11
FTDI k-line adapter(VAG-COM) and cracked Carsoft for Mercedes, Cascade. allow you to read and erase DTC
oleg213
Mr.Emo
69
08-28-2017, 03:41 PM #12
You know where to get the carsoft? Can't find anything at all. :o
Mr.Emo
oleg213
08-29-2017, 02:36 AM #13
Try that https://yadi.sk/d/JYX8MnlA3MQn2q
oleg213
Mr.Emo
69
08-29-2017, 06:41 AM #14
1mb? :o
Mr.Emo
1mb? :o
