STD Tuning Brakes w202 brake improvement
addi.bigg
OM605; 7,5mm elements
94
08-30-2017, 03:52 AM #1
Fellas,
What is the best option for improving brake performance on w202 chassis? Only limitation is that I would like to keep the 15" steel rims for the winter tires. Summers are on 16".
W124 4piston calipers with 295mm diameter discs would be ok for this package?
addi.bigg
Fellas,
addi.bigg
94
08-30-2017, 04:37 AM #2
(08-30-2017, 03:52 AM)addi.bigg Fellas,
I see W124 wont work.
W210 E300TD Brake disc and caliper would work?
This post was last modified: 08-30-2017, 05:57 AM by addi.bigg.
addi.bigg
addi.bigg
94
09-03-2017, 11:44 AM #3
(08-30-2017, 04:37 AM)addi.bigg
No one any ideas?
addi.bigg
No one any ideas?
erx
w202 om606
323
09-03-2017, 01:28 PM #4
With 15" wheels you don't have room for bigger brakes. 300td has minimum 16" wheels.
erx
addi.bigg
94
09-04-2017, 02:28 AM #5
(09-03-2017, 01:28 PM)erx With 15" wheels you don't have room for bigger brakes. 300td has minimum 16" wheels.
Thanks! As originally it didn't have 15" wheels is it 100% that it wouldnt't fit underneath it? The calipers are so far different?
addi.bigg
