STD Tuning Engine Difference between injection timing devices?
addi.bigg
OM605; 7,5mm elements
94
09-24-2017, 09:46 AM #1
Fellas,
Could anyone tell me what is, if there any, difference between the two following injection timing devices?
A 605 070 07 45
A 605 070 10 45
Is there any differences of the flyweights?
addi.bigg
Fellas,
A 605 070 07 45
A 605 070 10 45
09-25-2017, 01:44 AM #2
Most probably is the vacum pump attacment...
As far as my knowledge goes everithing is the same except the springs and total advance. I mean between advance sprockets , not those particular part numbers
This post was last modified: 09-25-2017, 01:46 AM by barrote.
addi.bigg
94
09-25-2017, 10:10 AM #3
(09-25-2017, 01:44 AM)barrote Most probably is the vacum pump attacment...
What is the importance of those differenct parts?
The timing will not be on the exact position with the not original pump attachement?
addi.bigg
09-25-2017, 02:34 PM #4
I don't understand the question... but the devices work in the in the same principle through out the engines...
They alow the start of injection to be anticipated untill a certain amount of degress and untill a certain rpm theshold.
The springs are what differs in the MB device... althoug some devices allow more advance/ anticipation to be reached...
As my knowledge goes...
erx
w202 om606
323
09-25-2017, 03:53 PM #5
First code seems to be for old piston type vacuum pump and second code for new type.
Random pictures, may not be with exact same codes but just for visual differences.
first code:
[Image: 1499670120415_block]
second code:
[Image: images?q=tbn:ANd9GcRoesKMyK7B2SSz0GfEqaN...DKWgPr-cpJ]
Vacuum pumps and timing sprockets must be in pairs and can't be changed even if changed as pairs because new type pump has extra pressure lubrication channel from engine front cover. So if someone wants to use different type sprocket and vacuum pump then engine front cover must be changed also.
This post was last modified: 09-25-2017, 03:58 PM by erx.
erx
first code:
second code:
addi.bigg
94
09-26-2017, 12:08 AM #6
(09-25-2017, 03:53 PM)erx First code seems to be for old piston type vacuum pump and second code for new type.
first code:
second code:
This is close to what I meant to ask.
I've changed the below part with vacuum pump to the below one also with the vacuum pump. So thats's ok, changed in pair.
My question would be that there can be any problem in timing of the pump because of this change because the two pump/sprocket assys may have different springs? Bad idle, noise run, anything.
addi.bigg
first code:
second code:
erx
w202 om606
323
09-26-2017, 04:31 AM #7
(09-26-2017, 12:08 AM)addi.bigg
first code:
second code:
If you changed them in pairs then was the gasket exactly the same? I think it isn't. I wanted to change the pump also but new type vacuum pump has extra oil channel from engine front chain cover and gasket is different. Bolt pattern is the same but no lubrication channel on old type engine. Maybe if you change it from new type to old then it might work.
I belive timing part is the same, only difference is pump attachment.
This post was last modified: 09-26-2017, 04:36 AM by erx.
erx
first code:
second code:
addi.bigg
94
09-26-2017, 10:29 AM #8
(09-26-2017, 04:31 AM)erx
first code:
second code:
The gasket was a bit different yes, so I've used sealant and not gasket. It works well.
addi.bigg
first code:
second code:
