Intake/charge temperature sensor relocation
I have just deleted the the EGR Valve on my W202 C250TD and will be re routing the intake pipework straight up from the intercooler into the manifold.
It looks like I need to bring an air sensor across to the pipework. Can I just buy a generic air sensor and hook it up or does the existing sensor need to be used?
Thanks
The existing sensor needs to be used, or one with a similar transfer function.
I believe the transfer function of it is similar or identical to the Bosch units used in many other applications so you should be able to find one that uses a 14mm thread instead of a clip type fitting.
(09-25-2017, 07:40 AM)baldur The existing sensor needs to be used, or one with a similar transfer function.
(09-26-2017, 03:22 AM)frans-c I just slotted mine in the intake tube between my K&N filter and turbo inlet. Runs fine, with no effect on fuel consumption that I've noticed in about 10 0000 km of driving.
(09-26-2017, 09:16 AM)PaddyEnglish86(09-26-2017, 03:22 AM)frans-c I just slotted mine in the intake tube between my K&N filter and turbo inlet. Runs fine, with no effect on fuel consumption that I've noticed in about 10 0000 km of driving.
Thank you frans-c.
The one I am talking about is located just before the EGR Valve. So it looks like it is measuring pressurised air temperature. So I will need to hook it up to the new pipework just before the manifold. I just need to find a suitable replacement
Thank you frans-c.
(09-26-2017, 03:32 PM)frans-c(09-26-2017, 09:16 AM)PaddyEnglish86(09-26-2017, 03:22 AM)frans-c I just slotted mine in the intake tube between my K&N filter and turbo inlet. Runs fine, with no effect on fuel consumption that I've noticed in about 10 0000 km of driving.
Thank you frans-c.
Yup, I was referring to that sensor. Many of the other guys simply let it hang loose somewhere out of the way - with no ill effects either.
Thank you frans-c.
(09-26-2017, 03:53 PM)PaddyEnglish86No, you'll have an engine light then.(09-26-2017, 03:32 PM)frans-c(09-26-2017, 09:16 AM)PaddyEnglish86 Thank you frans-c.
Interesting. Do you think it can be unplugged altogether?
(09-26-2017, 04:58 PM)frans-c(09-26-2017, 03:53 PM)PaddyEnglish86No, you'll have an engine light then.(09-26-2017, 03:32 PM)frans-c Yup, I was referring to that sensor. Many of the other guys simply let it hang loose somewhere out of the way - with no ill effects either.
(09-27-2017, 07:31 AM)juggs Mine has been running with it unplugged for the last 12 months, not caused me any issues
